Arducopter 3dr PLEASE help
Hi
I have an Arducopter 3dr frame and just got the APM2 loaded everything up but am having trouble getting it to fly it wants to go off at an angle instead off straight up
Read the instructions on the wiki but having trouble please help as i would love to fly this, as im a total newbie it would be brilliant.
  • anyone please help me with setting up my turnigy switches si can set more then one flight mode at the moment i have channel five working on one switch.
    Really confused by how program the turnigy to use a different switch or more then one switch ??? please help
    thanks
  • Update to this:---
    reattached all cables, made sure level etc and....... lifted perfectly :) but..... i think my settings on the radio are wron because I am syre they need reversing as I tried to hover for a while (2secs) but then tried to move seemed to be moving in the wrong directions - ending up coming towards me then I moved it quickly into a fence :( broke one one the props... so ordered a few more..
    But happy actually getting  it to  take off and sort of land....thanks for the replies deff helped..
    What Dany said. And also, make sure your frame is mostly balanced/centered. Moving your battery or having one arm that is too heavy just makes it harder, so if you can get things mostly balanced to start with, it is easier.
    And make sure you level properly on startup. If your horizon is not level, or if your quad is not balanced, it has the same effect... it will run away (usually in the same direction) The auto trim helps overcome this, but it works better if your motors are all level (no bent arms, or on-angle props/motors) your APM has a good level, and your craft is well balanced.
    Another important idea for new fliers ... when you are very low to the ground, you'll get a lot of ground effect. As scary as it is, try to get at least three feet off the ground quickly (if you can do it without crashing or racing your quad into a nearby bystander) and you'll have better flight characteristics, usually.
    Enjoy!
    channel 7 auto level trim is the way to go:
    Steps:
    1) assign Autotrim to CH7 with the planner (and to a 2 position switch in your tx)
    2) at the ground switch on/off the autotrim function and see if the led with autotrim enabled start to "rotate" (not the normal led blinking function)
    3) takeoff with autotrim off in windless condition, still your quad in the air and switch on autotrim and try to mantain your quad in the same position with a little stick movements,remembering that you have to make the correction and then back to center stick (not the throttle, lol) to see how he is placed in air... when you quad is firm enough switch off the autotrim function, land and disarm the motors
  • Calibrate your ESCs but mine never seem to take off 100% straight up. I have to adjust it slightly as it comes up but it's better once its a few feet off the ground.
DIY Robocars via Twitter
RT @breadcentric: See how the April AWS DeepRacer races have ended and a couple bits of news: https://blog.deepracing.io/2021/05/09/aws-deepracer-league-2021-update-11-end-of-april-special/ #AWSDeepRacer #Machin…
20 hours ago
RT @sunilmallya: Representation Learning +Instance Transfer to learn new reward functions along with advantage based filtering of new exper…
yesterday
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
RT @SmallpixelCar: Replaced AGX Xavier with @NVIDIAEmbedded Jetson Xavier NX. Now both cars look fast and clean https://t.co/jlcoY2EjZf
Apr 25
RT @chr1sa: Yesterday we had a record number of competitors (36) in our monthly @DIYRobocars virtual autonomous car race. We kept it going…
Apr 25
Apr 16
DIY Drones via Twitter
RT @chr1sa: After more than a year of only virtual races, @DIYRobocars returns to the newly renovated @circuitlaunch on May 22 for the resu…
Apr 11
RT @DAVGtech: And now available with LiDAR 🔥 https://twitter.com/Heavy02011/status/1381137016381964293
Apr 11
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #9 - #ParkingLotNerds #thunderhillracetrack, CA Join us for the next race April 24th,…
Apr 11
RT @DWalmroth: Weather's finally cooperating, looking forward to racing 1:10 scale autonomous cars outdoors again! @diyrobocars, @NVIDIAEm…
Apr 7
RT @AIDRI_: I finally succeeded in optimizing the trajectory and speed of a car on a #racetrack. Next step: implement a 2d controller and…
Apr 7
@jetdillo @circuitlaunch Actually the second *in person* event in a year. We do virtual races every month
Apr 2
Update: we're moving it back one day to Sunday (the 4th) at 11:00am instead
Apr 2
