Arducopter
Hey im noob in uavi have next components:Apm 2.6Frame x5251400kv turnigyEmax 4in1 esc2200mah turnigy baterryHobbyking hk6s remoteTelemetry 433mhz...Now here is my problem i did connect all right and then is a problem i plug bazerry on apm 2.6 run i arm the uav but motors don't spin only 1motor beep and work on throttle can anyone help mee?
  • did you calibrate the emax 4in1?
