Here are some pics of what should be from the folks here at DIY, A WORKING CODE!
I had to take different angle pics cause I was happy! All by myself! The required files are linked in case someone else spent the money for all of the options thinking they were supported like I did!
NOW YOU CAN USE THEM!! Thanks RCG!
Videos and proper tuts to get this working coming soon!
Hi Aaron,
I have been using the tutorial provided and the files provided above to config my UBlox gps and run my APM. While running Ublox gps on the Ucenter, i am able to read the data on Ucenter and 3D fix.
When i run the APM with the above code, i am not able to achieve the red LED. I am activating the Position hold mode and i am getting the A led & B led but not the C led.
What could be the problem?
There are some guys working in RC Groups on that (not sure if it's what you're using).
Have a look at the link http://www.rcgroups.com/forums/showthread.php?t=1286011
They've done GPS/Position hold, magnetometer, superstable mode, etc...
Leonardo
