Hi all
i have arducopter Quad : V 1.1
The Mission Planer : V 1.0.90
im trying to fly and trying hover the quadcoper like crazily when i try to take off and fail down its like when the gyro set in more sensevety
i connect the quadcopter with Mission Planer (APM PLANNER)
Then go to (Configuration) -----> AC2
then what should the normally Numbers ??
its the full setup and the frame type (+)
also the i check the motors connections and directions its okay
which version you asking about the mission planer or quadcopter ?
but i cant fly when i want take of its be like crazly
everything there looks normal to me. I will be partly intergrating defaults into the planner soon. but getting the defaults is the tricky part.
