Arduino Timeout Issue
DIYDrones,
I have been having trouble uploading custom firmware to the APM 2.5's (although it probably isn't version specific).  The problem is odd because I have two identical APMs, both of which are 2 weeks old.  Out-of-the-box I didn't have any issues, but recently one of the APMs gives a timeout error when loading custom firmware in Ardiuno.  Here is a copy of the console messages:
Building for ArduPilot Mega 2.x
Excluding arduino core from include paths
Excluding arduino core from link
Binary sketch size: 193,392 bytes (of a 258,048 byte maximum)
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x13
avrdude: stk500v2_paged_write: write command failed
.... it keeps going but I didn't want to paste it all.
I thought it may be a problem with corrupt firmware on the APM, so I decided to try and reload the original firmware from the MP.  There were no issues loading the firmware from the MP, but the same issues persisted when trying to load custom firmware in Ardiuno.  Has anyone come across this issue and solved it??
FYI: I have made sure to select the correct board, port, and chipset, so this shouldn't be related to the issue.
    Are they on different COM ports? If so, check the Set RTS on Close checkbox in the Windows Control panel for the trouble port.
xemone liked Max Gilson's profile
Aug 31
nick rymer left a comment on ArduCopter User Group
"I recently switched laptops and now have Windows 10. I installed Mission Planner on my laptop and plugged a mRo SiK Telemetry Radio into the USB port. The radio is not recognized on the com ports but is instead on the "Other Devices" tab in Device…"
Aug 20
