  • Are you using the Airspeed sensor. If yes, and it is "enabled" make sure it is reading airspeed, had this issue with my FX-79, found my airspeed sensor was not reading, and was enabled, and in every Auto mode, it thought it was stalling, so it dove to gain airspeed. Also, I just had a crash this saturday that involved "min airspeed" beign set FAR too low, my fault I know, but this created a situation where the airspeed was a bit too low, and turning from down wind to an up wind situation, the aircraft tip stalled into a irrcoverable spin dive. Out of curiousity, which airframe are you flying?
    • Jeff what is your RTL altitude?
    • I am not using airspeed sensor and it is disabled min air speed is well above stall speed. Airframe is custom cnc cut 3 part flying wing 2M span will post photos later.
      • Its 99.99% likely that Tridges recommendations will solve your problem.
        I recently bought pixhawk and the last firmware version I used until recently was 2.67, since then a new method of elevon mixing had been introduced, which had me stumped for a day until I found this page
        http://plane.ardupilot.com/wiki/arduplane-setup/first-time-apm-setu...
        Make sure to read it carefully in particular the chapter - New style elevon mixing EEPROM setup (ELEVON_OUTPUT option)
        • yes i already checked this and tested using elevon_output option in manual mode it is ok. i will do next flight after recalibration and will update.
          • Thanks to every body specially Tridge / Gary
            Just Tested with new calibration worked perfect tuned with auto tune.  tested FBW_A and auto mode also worked perfect. The P gains were too low as default . will test auto takeoff and land and will update.
            Ahmed
            • Today Auto takeoff worked perfect will try auto landing in next flight any suggestions on approach of autolanding height and distances.
              • I also am having this problem that you have now corrected. I am flying a Hercules wing on 4S, twin engine. The last two flights when I enabled RTL my plane ended up in a steep dive, both times I regained control. I am using the new digital airspeed sensor. My main question is, if I was flying at less then my cruise airspeed of 17 m/s when I engaged RTL, would the plane drop altitude to gain speed. Thanks for your help JEFF
        Ahmed, Tridge has responded, it is a setup problem please undertake the steps he has advised.
        • Gary /  Tridge one thing i cant understand it flew one mission with the same setting ok navigating all waypoints and then started orbiting over head.
DIY Robocars via Twitter
yesterday
yesterday
yesterday
yesterday
Nov 20
Nov 20
Nov 8
Nov 8
Oct 23
Oct 23
Oct 23
Oct 19
Oct 18
Oct 13
RT @araffin2: 🏎️ After hours of video editing, I'm happy to share a best of my Twitch videos on learning to race with RL. 🏎️ Each part is…
Oct 13
RT @a1k0n: Fully autonomous wipeout in the corkscrew at Laguna Seca @selfracingcars today. Got some tuning to do; this car is very fast, bu…
Oct 13
