t is made in China Arrow Hobby ,100% original,The Arrows Hobby F-15 Eagle is an American twin-engine, all-weather tactical fighter aircraft designed by McDonnell Douglas. The Eagle first flew in July 1972, and entered service in 1976. It is among the most successful modern fighters, with over 100 victories and no losses in aerial combat.Fourteen months in the making, the Arrows F-15 is lovingly recreated-from accurate panel lines to the adrenaline-pumping performance this is as real as it gets!With its twin 64mm EDF power system, large wing area and highly strengthened wing structure the Arrows F-15 can perform advanced aerobatic flight maneuvers along with exceptional high alpha capabilities without losing control surface authority.The twin engine McDonnell Douglas F-15 Eagle is an all-weather tactical air superiority jet that had its first flight way back in 1972. Entering service in 1976 it quickly became one of the world��s most successful operational fighters, with over 100 air combat victories to no losses. Powered by twin Pratt & Whitney F100-PW-220 after-burning turbofans that deliver a top speed of Mach 2.5, the F-15��s chief claim to fame is its incredible acceleration and manoeuvrability which, added to its impressive range, weaponry and avionics, have made it the U.S.A.F's primary fighter for decades.A truly iconic aeroplane which has been beautifully reproduced by Arrows Hobby in light and resilient EPO foam and treated to the eye-catching Oregon Air National Guard 75th Anniversary commemorative colour scheme. Fitted with twin 64mm 12-blade fans, a 6S power system and a scale retractable twist-n-turn undercarriage, this model beautifully mimics the appeal and characteristics of the full-size in everything from appearance to performance. Arrows models have a reputation for flying well and, again, this one's a peach. Offering a solid four-minute duration on the recommended 6S 4000mAh LiPo, the performance is close to perfect in both slow and high-speed manoeuvres. Agile, responsive and looking every bit the formidable US fighter, this is definitely a model that will make you grin Looking for a dog-fighting powerhouse with stable low-speed characteristics and excellent handling to take on the Mig-29? Look no further than the Arrows F-15!FeaturesHighly detailed pre-painted scale EPO foam airframe.Fast, glue- and screw-together assembly.Pre-installed high-quality hardware (motors, fans, ESCs, servos & retracts).Superior ball joint control linkages.Performance-optimised power-to-weight ratio.Latch-retained canopy for easy battery access.Scale, sprung retractable landing gear.Suits 6S 22.2V 3300 to 4000mAh 35C LiPo.Nine pre-installed 9g high-quality digital servos.Takes standard 6-channel radio.Magnetic, detachable nose cone. What's in the Box1x Factory assembled pre-painted fuselage with decals applied.1x Pre-painted 2-piece wing set with decals applied.1x Pre-painted 2-piece tailplane set with decals applied.1x Pre-painted 2-piece fin set with decals applied.1x Detachable nose cone.2x Pre-installed 2840 2280KV brushless motors.2x Pre-installed 40A ESCs with single EC5 connector.9x Pre-installed high-quality 9g digital servos.2x Pre-installed 64mm 12-blade fans.1x Screw and pushrod set.1x 2-piece detachable missile set.1x Main wing spar.1x Comprehensive instruction manual.Needed to CompleteThis is a PNP Version RC Airplane and requires1x 6-channel transmitter and receiver combo.1x 6S 3300 to 4000mAh 35C LiPo with EC5 connector.1x 6S compatible LiPo balance charger. to be complete.SpecificationsApproximate Flying Duration:?4 minWingspan900mm (35.4in)Length1345mm (53in)CG (Center of Gravity):125-135mm from the leading edgePower System:Brushless 2840-2280kV x2 unitsElectronic Speed Control:Twin 40A ESC with 5.5V 5A BECPropeller / EDF:64mm 12 blade EDF unit (x2 units)Servos9g plastic servos x 9 unitsLanding GearElectronic retractable main gearRequired Battery:22.2V 3300mAh 35CRequired Radio:6 Channel transmitter and receiver requiredAilerons:YesElevatorYesRudderYesFlapsYesBuild Time:15 minuteshttps://www.arrows-hobby.net/arrows-hobby-f-15-64mm-pnp-rc-airplane.html
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
