100KM
AttoPilot current reading
This is a re post from category but no respond. I hope someone will help here.
I've connect attoPilot to APM 2.0 as per the manual. I also do the calibration. The voltage reading for my 4 s battery is correct but the current reading is either 0 A, 1 A or 2A. That's all it show. Anything went wrong ? Thanks for your help.
  • Speaking of the Attopilot current reading is there a way to see in mission planner how much power has been used (mAh). I know that I can set total battery capacity but is it possible to see how much power has actually been used because the voltage can drop and be a less accurate indication.Thanks
    need more info. make sure you have the correct attopilot board selected
