Hi All,
  Does Copt  3.3.3 support this feature/function/mode  (which I believe is possible with DJI Ph) -
Pilot set the correct mode/params -
The pilot now initiate Auto-take-off / Launch  (via his tx cmd)
The vehicle launch and auto-take-off to a set height of eg 5m.
At reaching the required Alt, it will enter eg 'Pos-Hold' mode, with the Pilot now taking control.
(Mode/Alt pre-config via MP by Pilot)
If possible, how would one do that with Copt 3.3.3 without doing it in a Auto-Mission fashion.
 Is there a special mode for this feature?
If already covered somewhere in the forums,  please kindly point me in the direction.
Thank you for your advice on this matter.
I posted this in ArduPilot previously, with little response.
 Does this mean this 'mode' cannot be implemented, or is it that it is so very
 basic that nobody wants to comments, am I missing something in
reading as to what I want to achieve?
I really just want to know whether it is possible, and then if, 'how-to' ?
I am also posting this in ArduCopt 3.4
GertJL
  • I would recommend using the Tower app on a device attached to your transmitter. (similar to dji app) Using telemetry connection and Tower, you can use on screen buttons to arm and takeoff to a set altitude. Switching the mode on transmitter will regain control.
    • 3702259312?profile=original
      Forgot to upload the menu screen grab showing the mission planner arm and takeoff command.
  • Mission planner: { [CTRL] [F] quad: arm and takeoff } Question
    I found by accident this command in mission planner:"quad: arm and takeoff"
    Mission planner version 1.3.38 build 1.1.5983.12141
    Calling the sub menu by pressing [CTRL] [F} from the laptop
    This works without *any Transmitter on" Just from ground control laptop and telemetry with the aircraft Pixhawk/Pixraptor.
    There is now 27th June 2016 a command in mission planner which seems to do arming the aircraft and take off.
    I can't get any details of what exactly it is doing. Ichecked the "arming" part of the command and this effectively
    works.
    Without any detailsof what will happens after takeoff, I didn't check the "take off" portion.
    Regards
    Henri
  • Maybe I missunderstand your quesition, but you know the PILOT_TKOFF_ALT parameter?
    "vehicle climbs automatically to PILOT_TKOFF_ALT alt when taking off in Loiter, AltHold, PosHold, Sport (disabled by default, pilot's throttle input overrides takeoff)" from the changelog of Copter 3.3
    Isn't that more or less what you are looking for?
    • Hi Stefan,
       Thanks for your input.
        At this time I was not aware of this option.
         I assume you are referring to Copter 3.3.3?
      If I understand the option, in practice-
      1) Set the PILOT_TKOFF_ALT  (MP)
      2)  Pilot set the required mode ( eg Loiter, AltHold, PosHold ) via Tx
      3)  Press the Arm Switch on the PixHawk
      4)   Arm the Vehicle with Tx
      5)    On Thr-Up, the vehicle will do a Auto-Takeoff to PILOT_TKOFF_ALT
      6)   Releasing control to the Pilot in the mode which the Pilot selected with his Tx.
      7)  Pilot continues the flight
      If this is the case, then this feature is indeed what I wanted.
      I will test this option  and give feedback here.
      Gerhard
  • You can probably plan a mission with only the takeoff set up, then arm, select auto mode, and it should just go to your selected altitude and hover.
    • I guess that may be a method indeed.
       btw, from my understanding, one can only load one Auto Mission profile to pixhawk?
      If this the case, each time I do load a proper mission and I want to revert back
      to your mentioned method, I will have to re-load the particular mission?
      someone else comment in ArduPilot -
      'You can send takeoff cmd with desired alt in GUIDED, POSHOLD and LOITER'
         the person didn't elaborate, so I assume he refers to MP takeoff cmd.
      • That may be something for the future, it's all software so it would just take someone that knew how to write the code, if someone hasn't already.  I'd like to see that implemented, you could have it on a switch, or it could be as part of a mission where the copter goes to the altitude and holds in loiter until you put it in auto mode.  That would be useful if you plan a mission but want to quickly check your reception in a particular area before you fly the complete route.
        • Hi yes,
           I was thinking that the feature could be an additional 'mode' option -
          Operation for example could be in broader term outline -
          1)  'Auto-Launch' (AL) mode can be selected via a Switch on the Pilot's Tx
          2) As per normal proc, the Pilot now select on the Tx the flight-mode which the craft must enter into once the Alt has been reached. (Alt configured in MP)
          3) On Arm & Thr-Up it will execute the 'AL' Mode and 'hand-over' control to the Pilot (now as per the Pilots Flight mode selection eg Loiter) once Alt has been reach.  ( For safety the AL mode only executable if the pilot select a gps mode eg PosHold or Loiter. )
          4) The Pilot continues with flying as per normal.
          Well, anyway, I think you get my drift on this option which I think can be very usefull.
          I hope one of the Devs could look into this AL-mode application development.
          Anyway enough of my day-dreaming :)
           Thanks for sharing your interest in this topic
          Gerhard
  • Yes, it can do that, and much more than the toys you mention.
    Read ardupilot.org/copter
DIY Robocars via Twitter
RT @DanielChiaJH: @a1k0n @diyrobocars @circuitlaunch And here's the final showdown! Video courtesy of @chr1sa I think I was a little faste…
4 hours ago
RT @DanielChiaJH: @a1k0n @armand_dpl @SmallpixelCar @diyrobocars @circuitlaunch I use @foxglovedev Foxglove Studio for my visualization nee…
4 hours ago
4 hours ago
RT @a1k0n: @DanielChiaJH @diyrobocars @circuitlaunch Here's my car's view of that race. About 8.4 second lap times for laps 2 and 3... both…
Monday
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
Sunday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
Saturday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
Saturday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
