Autotune Problem
Hi all.  I posted this in the wrong forum yesterday, so I just edited it to post it to the 3.x forum.  I am hoping someone can help me out.  I appreciate any help that you can provide.  My quadcopter flies fine except for the issue noted below.  The problem I have is when I start autotune, everything goes fine until usually a minute or two in.  The quad then pitches or rolls as it normally does in autotune but it doesn't come back to horizontal and just takes off full throttle holding the pitch or roll autotune had the quad perform.  I have been lucky to recover from all of these unexpected maneuvers.  There was one time that the quad did this and flew a good 50 yards away before I was able to get control again.  I just don't know what is wrong with it.  I have never been able to complete an autotune.  It always fails after one of these maneuvers.  I was reading that there are a few things that can cause an autotune to fail.  One is flexible arms on the quad.  I tested mine and they do flex a bit, but I am not sure if it would be enough or even the reason the quad does this in autotune.  The specs for my quad are listed below.
In stabilize, the quad flies great except when I initiate an oscillation by moving the pitch/roll stick back and forth.  The quad then goes into an oscillation that is almost unrecoverable.  The only way I can recover from it is if I lower the throttle and gently increase it.  If I give it more throttle or adjust throttle to keep the same altitude, the quad will most likely crash.  I tried re-tuning the quad but it does the same thing.
I have completed several planned missions with the quad.  I wanted to complete an autotune before putting my camera gimbal on the quad.  I am uneasy about putting it on because of the oscillations that can be induced and potentially causing a crash.
My son took a video of the problem but he's only 5 so the video isn't all that great and didn't capture the problem the second time it happened.  You will see the quad take off to the left during auto tune but I recover quickly in the video.
http://youtu.be/c3TMNY-Hmgs?list=UUx4C9BKl4FobHFG-ln4v-yQ
Hobbyking AQ-600 frame
Sunnysky X2216 1100KV motors
Turnigy Plush 30A ESC's
10x4.7 props
APM 2.5 with external compass
3DR uBlox GPS with compass
Arducopter firmware version 3.1.5
5000mAh 3S battery
2014-08-30 11-03-13.log
  • Zach,
    I will definitely let you know if I find out what the problem with my quad is. I'm just not sure what else to try. I tried looking at my logs, but interpreting them isn't the easiest thing to do. I will have to go back and see if ATDE data is included in my logs. If not, then I should probably go do anther auto tune flight with that enabled and upload it to my post. I'll try and get another video also.
    • Hi Arion,
      I had some luck yesterday with my quad. I noticed the quad would oscillate around the 1-2 axis fairly quickly, probably just under 10 Hz in a pretty unstable way. I also noticed motor (2) on my quad was angled slightly towards the center of the quad.
      I loosened all of the arms and re-torqued the bolts while the quad was level which seemed to slightly lessen the oscillations, but the biggest difference was made when I calibrated the ESC's. Video demo here: https://www.youtube.com/watch?v=gYoknRObfOg. I would suggest giving this a try. After calibration my oscillations were gone but the quad was still 'twitchy'. No where near as bad as before and seemed to be working at a level that would allow autotune... so I tried it. Success!
      After autotune the quad flew rock solid for 3 batteries. (45 minutes).
      I'd give the ESC calibration a shot if you haven't already.
      Zach
      • Zach,
        Thank you so much man.  The ESC calibration worked!  I had zero problems after I did that.  I could not induce an oscillation when I tried stabilize.  I then tried autotune and it completed with no problems!  My quad flies perfect now.  Thanks again man.
        Arion
  • Hi Arion -
    I had a look at your video. It looks similar to what I experienced today. Let me know if you figure out what is happening and I'll do the same.
    Another note I remember now after reading your post I only put 1 out of the 4 screws on for each of the quad legs (F450 frame) I have so it's possible there was some flex there. I could see that resulting in the instabilities I mentioned in my post but have a hard time believing it could cause the quad to power up and blast off to the left (mine was left too...) the way I saw today and you show here.
    Zach
DIY Robocars via Twitter
Friday
Friday
DIY Drones via Twitter
Thursday
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
Thursday
Thursday
David Hori liked Isabella Domi's profile
Wednesday
RT @Heavy02011: ⁦@diyrobocars⁩ Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ ⁦@f1tenth⁩ ⁦@DAVGtech⁩ ⁦@DWalmroth⁩…
Jan 11
RT @chr1sa: New car designs coming for our next @DIYRobocars @donkey_car virtual race on the 23rd. Choose any one you want at race time Le…
Jan 11
RT @RoboticMasters: Thanks to @EllerbachMaxime and the Sydney Uni Capstone Students the @donkey_car @diyrobocars simulator is getting a ma…
Jan 11
Jan 6
Dec 28, 2020
An interesting line-following simulator to use with with your robocars: https://github.com/ron-grant/LFS
Dec 23, 2020
Dec 23, 2020
An improved version of the @IntelAIResearch OpenBot: https://diyrobocars.com/2020/12/14/an-improved-version-of-the-intel-openbot/
Dec 14, 2020
An improved version of the Intel OpenBot https://ift.tt/2KkHT8Q
Dec 14, 2020
Dec 10, 2020
