  • I had that problem , it looks a vibration problem. do you have a .log
    • So yes it was a vibration problem. Work so much better when I put in some dampening. I just find it hard to understand if I have high vibrations.
      2015-03-24 17-14-05.tlog
      • I just read in other post that 3.3 vers is going to solve this problem with vibs :)
        • The problem with high Z vibrations is that it can exceed the 8 g range of the accels. Believe it or not it can filter out vibrations from ~ 1 g on the Z accel with a vibration great enough to exceed 8 g. This causes clipping and information is lost, copter thinks its falling so the inav causes a rapid climb. The solution was to set the accels for +/- 16 g range. I think it samples at a higher rate, so don't know if this change could be done to 3.2.1 and work on APM. It might, but I don't think the devs are going to support APM's any more. Just use the last good version. I think this change could be worked back to 3.2.1, maybe.
        • They are saying v3.3 does not fit on the APM.
          http://copter.ardupilot.com/wiki/common-autopilots/common-apm25-and...
          • BUAAA!!! we have to put Pixhawk in wish list.
            • Yeah tell me about it.. I just ordered a new APM too...
  • yea I had same problem with horrible alt hold and loiter....it all want away when i went back to 3.1.5....not sure why the reason, I know I have some vibrations to deal with but it might seem that 3.1.5 handles it better...there are a couple of threads out there about this, might be worth a shot to try 3.1.5
  • what version?
