When I try to calibrate Compass it displays "BAD compass health" error I have 3DR UBlox GPS + Compass Module and I disabled failsafe option then it armed and fly well but it's yaw motion and loiter mode not working can anybody guide me how i can remove this error?
did u fix it?
I too had "Bad Compass Health" until I moved the telemetry wires away from running along the top of my Pixhawk. Any wire carrying electric current produces a magnetic field circling it. The more electric current the more intense is the magnetic field. Electric Motor wiring is the worst, however other lessor current carrying wires can also affect the compass if close enough to the sensor.
I verified that my 3.3 regulator wasn't blown, checked all the hardware, etc.
I did the calibration outdoors many times, away from any interference, to no resolve, no cell phone in my pocket, nothing to interfere. I checked and rechecked my wires, mounted on a mast, twisted the power wires, everything. I am using an APM 2.6 on a DJI F550 with Spektrum AR8000/DX8 setup.
Mee too, on APM 2.5 I have double and triple checked that I properly cut connection between pads on APM to disable on board compass. I can see the board all the way through so I think the jumper is cut. However now I see 'bad compass health' on mission planner and compass reading off 90 degrees. For some reason the on board compass on APM seems to still be working because I see copass movement on mission planner but when I move the ublox compass I see no movement. Any ideas?
I have the EXACT same problem. off by 90 degrees and no change direction change when I move the external gps/compass. I do, however, have a GPS lock and it looks accurate. Any help would be appreciated.
Same here. What is up with this? It just suddenly started this behavior.
same for me.
I can not calibrate the compass (no data appears on the Mission planer window of calibration) but I can see the compass movement in the Flight Data window.
Even it is show bad compass health, seems it is working.
Any idae?
Me too, with version AC: 3.1.0 (build for Pixhawk) What version do you have?
Menno
Me too.... but I am with PX4
And me too on apm2.5.2 , any solution?
