beginning APM2
Hello,
I am just getting into drones and decided to buy an APM2 module, to be used in an EasyStar setup. So far I've put this on my list:
https://store.diydrones.com/APM_2_0_Kit_p/br-ardupilotmega-03.htm
https://store.diydrones.com/Kit_MPXV7002DP_p/kt-mpxv7002dp-01.htm
https://store.diydrones.com/Xbee_Telemetry_kit_p/kt-telemetry-xbee.htm
https://store.diydrones.com/Ardupilot_Mega_Minimal_OSD_p/br-apmminosd.htm
https://store.diydrones.com/FTDI_Cable_3_3V_p/ttl-232r-3v3.htm
https://store.diydrones.com/ArduStation_p/de-0001-01.htm
https://store.diydrones.com/Easy_Star_Electronics_Chassis_With_Pan_Tilt_p/ez-chassis-cam.htm
Are all these compatible? The ArduStation mentions compatibility with only the original AP and APM 1.x. How are the things standing for APM2?
Also, do I need the FTDI cable? What is it used for?
Thank you,
Cosmin
Edit: Removed the FTDI cable, as it is not needed for the APM2 hardware (chip already mounted).
  • The FTDI cable would be for programming an Arduino that does not have a built-in FTDI - This is not needed for the APM2 (as well as APM1) since they have this on-board, and only require a normal micro USB cable, which looks like it is included with the kit.
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
