Hi all,
Is it not good idea anymore to run SITL on windows 7 platform (with cygwin interface plus pyserial and other add ons) ? As I see dev.arupilot.com has removed the previous SITL tutorial, which was showing instruction to run the SITL on windows 7 platform. Instead, now they are suggesting to run ubuntu inside windows with VMWare and then perform SITL ( Latest Tutorial). I couldn't understand reason behind it very well.
Please tell me , is it reccomended to run SITL with all LINUX platform or I can still do it on Windows ?. Or should I run Qground control with XPlane ?
Also curretly I am following this tutorial from old website (Old Tutorial) and I am stuck at a step where we make
$ cd ArduPlane
$ make sitl
I am getting the "C:/GIT/ardupilot/mk/environ.mk:44: *** ERROR: cannot determine sketchbook location - please specify on the commandline with SKETCHBOOK=<path>. Stop." And I couldn't figure to set a path for sketchbook, though I tried setting up the path used in Arduplane IDE.
Hi I've added the line to .bashrc as specified in the new page at http://dev.ardupilot.com/wiki/sitl-native-on-windows/
Now when I cd in ardupilot/ArduCopter and then try running
make sitl -j4, I'm getting the same SKETCHBOOK not found error.
I cloned it off GitHub and have followed the instructions so far as given. I also didn't understand where to check for space in the directories as I didn't find any.
I have no idea what to do and any help is appreciated.
Thanks!
I'm getting the same sketchbook error, except it happens no matter what I try and make. Anybody got an idea?
Hi Nizobe,
I couldn't solve that but I stopped using that tutorial. Instead I started using the newer tutorial released by them ( http://dev.ardupilot.com/wiki/setting-up-sitl-on-windows/#Setting_u... ). I was able to perform the simulations successfully.
Which tutorial are you following ?
Hi Anand,
I'm following the guides from this page http://dev.ardupilot.com/ . From the section "Getting Started With the Code" from the beginning up til Editing with Eclipse. And then I tried the EZ walkthroughs as well. No luck :/
I'm trying to modify the actual firmware for custom use so SITL is a bit down the road for me.
Hi Nizobe,
Sorry It skipped out of mind to reply earlier.
Are you trying to setup the the SITL or something else ?
No, just the code itself off GitHub. I discovered the issue was a path to my repos that had spaces in it. This didn't play nice at build time. I solved it by moving my repos elsewhere on my local machine. Thanks anyway!
A year later... I just hit the same issue and removing the spaces from the directory name fixed it. Thanks for the hint!
