Hi All,
I'm looking to get a 3DR telemetry kit for my APM 2.5 and I'm not sure what the best frequency is for NZ conditions - 915 or 433 Mhz? It looks like both are supported here and I understand that you get greater range with 433 but that there might be more interference there from portable phones, etc.? Also, are the standard aerials good enough or would some sort of circularly polarised antenna be better?
Any advice would be much appreciated.
Cheers, Andrew
  • Jack - we want to set up a system to operate the MavLink on the proper frequency in NZ too.  Did you leave your 433 Mhz mavlink set up as default or did you change the frequency?  If you changed the frequency, how did you do that?  I read https://code.google.com/p/arducopter/wiki/3DRadio#Support_for_diffe...  that confirms the frequency CAN be changed, but I must be overlooking HOW to change the frequency.  Can you please point me to the HOW TO change the correct frequency of the MavLink for NZ?
    Thanks!
    Bret C
  • Under Radio Spectrum Managements General User License, the maximum allowable transmit power between 915-928mHz is just over 3mw. Between 433.05-434.79mHz you are allowed just over 25mw. You have a much larger band width at 915mhz but much lower allowable output power. I use 433mHz myself and it is perfectly adequate for my needs where I typically fly within a couple hundred meters.
  • Lower frequencies are always better than higher frequencies. Lower freq however require larger antennas but they give more range on the same power and have better object penetration abilities. The problem with higher frequencies (eg 5.8g) is they are very poor when items like trees get in the way. Its not a coincidence that higher freq were selected for items that require low range like cordless phones and wifis (5.8g) while mobile networks (900mhz etc) have much lower frequencies
  • Hi Andrew,
    I have been using the 915 mhz aerial for a year now with no issues. Gets reasonable range around 800m from GS.
  • Hey Andrew, I am from Nz too, did you ever find out your answer? I was looking to get one too but was unsure on the frequencies.
    Cheers
    Warren
    • Hi Bret,
      I believe I did configure the max and min frequencies using the AT command procedure described on this page:
      http://copter.ardupilot.com/wiki/common-using-the-3dr-radio-for-tel...
      There is a GUI in mission planner you can use to configure many parameters also described on that same page. Watch the power level is correct!
      Jack
      • Thank you Jack:
        Bret C
  • Also, the terrain I'm going to be flying over is mostly rural and possibly a bit hilly.
DIY Robocars via Twitter
Jan 28
RT @Heavy02011: ⁦@diyrobocars⁩ : A Home-brew computer club* for Connected Autonomous Driving. talk at #piandmore ⁦@PiAndMore⁩ on Jan 23rd h…
Jan 23
RT @a1k0n: New blog post! Deep dive into my ceiling light based localization algorithm which runs in 1ms on a Raspberry Pi 3: https://t.co/…
Jan 23
Great new guide to using @donkey_car https://custom-build-robots.com/donkey-car-e-book-en
Jan 23
RT @chr1sa: The next @DIYRobocars virtual AI race is tomorrow morn at 9:00am PT. You can watch live on Twitch https://www.meetup.com/DIYRobocars/events/275268196/
Jan 22
New version of Intel OpenBot! This resolves many of the issues with the first version, including a much smoother tr… https://twitter.com/i/web/status/1352395636369313798
Jan 21
DIY Drones via Twitter
Using ArduRover with an RTK GPS https://ift.tt/2N9I3RO
Jan 18
Jan 18
Jan 18
Jan 15
Jan 15
Jan 14
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
Jan 14
Jan 14
RT @Heavy02011: ⁦@diyrobocars⁩ Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ ⁦@f1tenth⁩ ⁦@DAVGtech⁩ ⁦@DWalmroth⁩…
Jan 11
RT @chr1sa: New car designs coming for our next @DIYRobocars @donkey_car virtual race on the 23rd. Choose any one you want at race time Le…
Jan 11
