Big Crash testing my Quad. Can anybody help me?
Hello,
First of all, let me introduce my quad configuration and the crash details.
We have a Tarot T960 hexacopter configuration based on a APM 2.6. We have tested many times and it flies really stable.
This morning, we decided to do the first flight of a modification based on this frame, but in this case, just with 4 arms, in quad configuration. The controller in this flight test was a pixhawk with APM 3.2 version.
We were testing loiter mode in order to measure the time autonomy with a new battery ( Multistar 10000maH). It was stable and after 3 minutes of flight, something happened and drone fell free and crashed.
I have downloaded the log, but after analysing it, I can not figure what happened and which was the problem.
Please I need your help in order to determine which problems we had in order to not commit the same mistakes.
Thank you!!
* I recorded the crash, so I will update the topic with the link of the video. Probably it helps in the analysis.
*I have attached the log file.
2016-03-24 12-30-27.log
    • Thank you everyone for the help, it is very useful for me.
      Here you can watch the video I uploaded a few hours ago. Probably it can show us more details about the problem.
      https://www.youtube.com/watch?v=j67Sb6-OR1w
      • GLUP!!!
  • See that you are in nice loiter and at the end droll and roll separate, your hardware couldn't follow what controller was asking for, that'common mechanical failure log.
    3702211738?profile=original
  • It looks like at 41,000 it started to roll right and pitch up.  The flight controller cut all power to motor number 3 to gain level altitude but it continued to roll.  It increased power to the other three motors so I would say it was motor number 4 that had the problem.
  • It's look's like a hardware fail, check your motors, esc props, perhaps motor nº3
    • Thank you for the info Cala. Really fast reply :D
      I would like to learn more about logging and how I can check failures. Could you please tell me how did you see this problem?
      Thanks!
      • A la noche te posteo unas fotos
