Build ArduPlane-v2.75 to Pixhawk
How can I build ArduCopter v3.1 (inside ArduPlane-v2.75 folder) for pixhawk?
If I use the github.com/dijdrones/ardupilot/ArduCopter I have version 3.2, but I want version 3.1 of ArduCopter.
But if I replace the ArduCopter v3.2 in the original zipfile from github with the ArduCopter v3.1 it will not build for px4 (with 'make px4' etc...).
Can anyone explain how to do this?
  • This is the answer: You can get older versions (a.k.a. releases a.k.a. tags in github) by checking out these 3 links:
    https://github.com/diydrones/ardupilot/releases
    https://github.com/diydrones/PX4Firmware/releases
    https://github.com/diydrones/PX4NuttX/releases
    Always use matching versions of these three directories, if you don't chances are it won't compile (correctly). Indeed, as you can see not all ardupilot release come with a maching PX4Firmware and PX4NuttX release, so possibly not all ardupilot versions can be build for Pixhawk. (Correct me if I'm wrong).
    If you use this guide http://dev.ardupilot.com/wiki/where-to-get-the-code/ or http://dev.ardupilot.com/wiki/building-px4-with-make/ and the links in there, you'll have the latest (developer) version, this might not be what you want. You for instance might want the latest stable release that MissionPlanner flashes to your Pixhawk when you select ArduCopter, -Plane, -Rover there. Checkout the version number of this stable release in MissionPlanner and look for this version in the three links above.
    Enjoy ;-)
    • So I've been able to compile different versions of ArduCopter because I'm able to download the same release of the PX4Firmware and PX4Nuttx repositories.  For ArduPlane, I don't see any PX4Firmware and PX4Nuttx releases that say ArduPlane in their listing.  So how do you get the proper source code for the ArduPlane stable releases.  I'm looking to compile the most recent ArduPlane firmware so I can do HIL with mission planner.
      Please let me know how to find the correct PX4Firmware and PX4Nuttx files for the ArduPlane stable version.
      thanks!!
      Bill
        Bill,
        If you look in the dataflash logs you should see somewhere near the top-ish it has a list of git has tags for ardupilot, PX4Firmware and PX4NuttX.  the tags are shorter than normal but still, if you do a "git checkout <tag>" then it should get the exact version used.
        I'm more copter than plane so I don't know much more than that but perhaps Grant or Tridge can help if you email drones-discuss@googlegroups.com.
        • Randy,
            Just wanted to let you know that I was able to figure it out.  Your feedback was spot on.  I just didn't realize that the 8 character code was the tag and refers to the last commit in the repository that was used to make the firmware.  However I think there is a problem with the Arduplane 3.2.0 tags for PX4 and Nuttx repositories.  when I tried to check out those tags, it told me that those tags did not exist in the repository.  So I went back to ArduPlane 3.1.1.  Those tags worked and I was able to build the ArduPlane 3.1.1 firmware.  Is it possible that the tags were copied incorrectly into those messages or is that all automated?
          Thanks again for the help!!!
            Bill,
            Happy to help.
            Those git hashtags are all automatically copied so they should always be fine.  We occasionally need to do a forced update to git to bring in all the changes from the px4 guys but my understanding is that that does not affect existing git hashtags.  I don't know about the release tags though (like "ArduPlane-3.1.1") it may blast those which would explain what you're seeing.
            • Randy,
              So I went back and compiled a hil version of copter 3.2 for Quad and Heli frames. I played with the quad frame in x-plane. I had to disable the prearm checks and the state info was coming across and I got the Pixhawk to arm. Of course the outputs to control the helo were motor speeds so it didn't work correctly.
              So I tried the Heli in x-plane and it would not receive the state information and then wouldn't arm. In the status it said "waiting on HIL STATE info. I don't understand why it would see the data in Quad and not for the Heli frame. Any ideas?
        • Randy,
            Thanks for the prompt response.  Where would I find the dataflash logs?  do you mean a download from the pixhawk.  They are typically named like <date>.bin.log.  The one I looked at had the following  info in it
          MSG, ArduPlane V3.2.0 (b88e6b63)
          MSG, PX4: 45694507 NuttX: 2d09d16d
          MSG, PX4v2 00380029 3233470E 31363032
          There were no tags in the PX4Firmware or PX4Nuttx repositories that had the ArduPlane V3.2.0 tag
    You'll likely need to use the code from the ArduCopter-3.1.1 or ArduCopter-3.1.2 branches inside of GitHub.  You also need to be sure to use the correct version of the PX4Firmware and PX4NuttX repositories.  There should be tags (aka "releases") that correspond to the arducopter version in those repositories.
DIY Robocars via Twitter
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
1 hour ago
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
1 hour ago
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Monday
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Monday
Monday
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
Aug 28
Aug 24
