Buying Turnigy 9x
Hi All,
I'm about to build an ArduCopter :-).
I see two different types of Turnigy 9x out there.. which one should I buy? TX-9X-M1 or TX-9X-M2? Planning to install ER9x as well.
thanks and regards,
Japi.
    Thanks everyone, just ordered M1. M2 is OOS. Hoping to make it a M2 once I receive it...
  • The left stick isn't spring loaded on the m2, whereas it's the right stick that isn't spring loaded on the m1. The non-spring-loaded stick is used for throttle. Ultimately, it's your choice which one you want to use, but most people have the throttle stick on the left.
  • Buy the Mode2. Everybody is using them.
  • M1=Mode1, M2=Mode2
    The only difference is the position of the 'missing' Nullpos feder (for throttle). Mode1=Throttle right.
    It's very easy to change the Mode in a Turnigy 9X by yourself.,, so you can buy what's in stock  :)
