Hello,
I have a Pixhack flight controller, and I am used to changing the ends of cables so that accessories designed to work on the Pixhawk, can plug into my Pixhack instead.
I am seeking clarification on one port in particular. This is the CAN port of the Pixhawk, and where the equivalent pins would be on the Pixhack.
I am trying to connect the Zubax GNSS 2 module because I want to take advantage of having an external barometer.
Here are the pin out on the Pixhack:
3691302644?profile=originalThe CAN port on the Pixhawk is as follows:
Pin 1 = VCC +5V
Pin 2 = CAN_H +12V
Pin 3 = CAN_L +12V
Pin 4 = GND
As you can see in the picture above, there are no pins labelled CAN_H or CAN_L on the Pixhack. There are however, CAN_T and CAN_R. Are these the equivalent? If so, which is which?
  • Hi Chuck,
    Unfortunately, Pixhack doesn't have a CAN bus interface. It offers only a CAN transceiver interface, which requires some external circuitry. I'd suggest to go with Pixhawk or something alike.
    Pavel.
    • Thank you Pavel.
      I have ordered a Pixhawk which should arrive early next week. I will give it a go as soon as it arrives.
    • can transceivers are pretty cheap little boards though on eBay if you are handy with these things...
sam liked Jimmy Oliver's profile
Aug 25
Mike Whitney liked Mike Whitney's profile
Jul 19
