Hi there ,
I've attached the compass to the quad as the image below show (APM points forwards - between yellow arms). and the compass is Rotation_Roll_180.
When I'm calibrating the compass I keep getting reversed results (North shows South).
I've tried rotation none , yaw 180 , rotation_pitch_180 without luck.
1. Does this affect loiter mode ? Alt hold works fine , loiter and RTL don't work well , quad drift and fly somewhere it shouldnt.
2. What can I do in order to get good results from compass ?
Attached image how I mount my Ublox.
    • either u can manually repair it or try to search in ebay
      • The black cable was torn from the white connector , i don't see a way to "re insert" it , and the yellow was cut id the middle....
  • I had the same prob like you(EAST was WEST and vice versa) and loiter was highly unstable.....So while calibrating I use ROTATION_NONE . After doing this I found the compass gauge gives the proper direction. Now my RTH and loiter is ok
    • I've calibrated compass in my room , the directions looks ok.
      Went out to porch , no GPS FIX and the directions are bad again.
      I think ill go outside with the laptop and see how it behave there.
      • you must wait for some time to lock gps... if GPS is locked u can see blue light of APM become solid...
        • I think I can't arm the APM if I don't have GPS lock.
          I'll go down soon and re-test it.
          • yes make pre arm check disabled or skip GPS
            • My pre arm is set to Enabled.
              I'm going now down to open field with laptop and quad.
              Hope all work fine :)
              be back soon.
              https://storage.ning.com/topology/rest/1.0/file/get/3702865322?profile=original
              • okk best of luck....., while enabling pre arm chk make sure all of your sensors are working and calibrated properly.... otherwise apm will oppose the copter to arm
                • Can I do the tests indoor or it must be outside ?
