Is it possible to upload the waypoint info to APM once at startup (using mission planner) and then let it complete the mission without (or beyond the range) of the telemetry system?
I think it should be possible. I just cant find any documentation for the same.
Vikrant
  • u4eake,
    Maybe the solution to really long distances is to use 2G/3G/4G telemetry? One of the phonedrone cards and a mobile phone sitting on the plane acting as a missions planner. I guess the SW is not there yet.
    Vikrant
  • Yes, I do understand the risk of going beyond the range of telemetry control.
    I just wanted to understand what are the limitations. No way am I going to try this now (I'm just getting started with APM), but maybe in the future :)
  • T3
    You can fly beyond telemetry and beyond TX range. Hell you can fly until the battery dies and land. But good luck finding the copter. One guy flew under auto with FPV and he went beyond control, but could still watch the flight. Pretty cool.
  • Thanks for your replies guys!
    So if RTL is the last command of the mission (and GPS got the correct location for Home and there is enough battery for the mission and ...) it is ok to go out of the range of telemetry?
  • Not sure I understood correct your question, but I can say that when you are in Auto mode (with waypoints), even you are beyond the range of telemetry, the mission will continue as per waypoints. You need to considered if you have any failsafe defined and also you can not more trigger RTL or Stabilize or any other mode when you are  beyond the range of telemetry.
  • yes. when you hit write, it loads the waypoints onto the apm board, and then when you go into auto mode it flys the mission. even if you fly out of your tx range, it can complete the mission (depending on failsafe setup)
Laurie J. Troy liked Jasper Kueppers's profile
Apr 1
Timothy Miller liked Joseph Udofia's profile
Mar 18
Joseph Udofia liked Joseph Udofia's profile
Mar 3
