CHDK Scripts & Parameters problem (Cont.)
Hi, this week i´ve been doing some aerial photography, with my skywalker, canon camera and CHDK script.
More specifically, im using the Canon SX260 HS powershoot hacked with the intervalometer from dronemapper guys. I detect that this script wont work totally well if you speceify a photo interval of under 3 seconds. This is because the camera just cant shoot in continous mode under 3 seconds at a time.
So i posting this as a head up.
PS: If you specify, in the parameters, a interval of, let say, 2 second. The camera will take shoots continously, yes, but the script will never end and the lens wont colapse. wich is a bad thing because it can be hit or something can occur to the lens mechanics.
  • Andy, this is not entirely truth, because if you set the focus on manual, you can get flat 2 seconds per frame. I´ve done some testing on this with a stopwatch
    • @Andreas, Thanks for updating me, looks like some more tweaking is needed. Cheers, Andy
  • This reply was deleted.
    • Hi Ben, did you find out what bit mask is required to log CAM messages?
  • Andreas,
    It may be the speed of your memory card that is slowing down your rate of image capture.  Make sure that you have a Class10 SD card in it.  With one of these in an SX260 I get 2-3 seconds fine.
    Good luck!
    Jimmy
  • Have you turned off the image review option? By default is set in 2 seconds.
