Code Pyton to VB.net
Hi people!
I want to convert this http://principialabs.com/joystick-control-of-a-servo/ program pyton to VB 2010.
Code:
#!/usr/bin/env python
# joystick-servo.py
# created 19 December 2007
# copyleft 2007 Brian D. Wendt
# http://principialabs.com/
# code adapted from:
# http://svn.lee.org/swarm/trunk/mothernode/python/multijoy.py
# NOTE: This script requires the following Python modules:
# pyserial - http://pyserial.sourceforge.net/
# pygame - http://www.pygame.org/
# Win32 users may also need:
# pywin32 - http://sourceforge.net/projects/pywin32/
import serial
import pygame
# allow multiple joysticks
joy = []
# Arduino USB port address (try "COM5" on Win32)
usbport = "/dev/ttyUSB0"
# define usb serial connection to Arduino
ser = serial.Serial(usbport, 9600)
# handle joystick event
def handleJoyEvent(e):
if e.type == pygame.JOYAXISMOTION:
axis = "unknown"
if (e.dict['axis'] == 0):
axis = "X"
if (e.dict['axis'] == 1):
axis = "Y"
if (e.dict['axis'] == 2):
axis = "Throttle"
if (e.dict['axis'] == 3):
axis = "Z"
if (axis != "unknown"):
str = "Axis: %s; Value: %f" % (axis, e.dict['value'])
# uncomment to debug
#output(str, e.dict['joy'])
# Arduino joystick-servo hack
if (axis == "X"):
pos = e.dict['value']
# convert joystick position to servo increment, 0-180
move = round(pos * 90, 0)
if (move < 0):
servo = int(90 - abs(move))
else:
servo = int(move + 90)
# convert position to ASCII character
servoPosition = chr(servo)
# and send to Arduino over serial connection
ser.write(servoPosition)
#print servo, servoPosition
elif e.type == pygame.JOYBUTTONDOWN:
str = "Button: %d" % (e.dict['button'])
# Button 0 (trigger) to quit
if (e.dict['button'] == 0):
print "Bye!\n"
ser.close()
quit()
else:
pass
# print the joystick position
def output(line, stick):
print "Joystick: %d; %s" % (stick, line)
# wait for joystick input
def joystickControl():
while True:
e = pygame.event.wait()
if (e.type == pygame.JOYAXISMOTION or e.type == pygame.JOYBUTTONDOWN):
handleJoyEvent(e)
# main method
def main():
# initialize pygame
pygame.joystick.init()
pygame.display.init()
if not pygame.joystick.get_count():
print "\nPlease connect a joystick and run again.\n"
quit()
print "\n%d joystick(s) detected." % pygame.joystick.get_count()
for i in range(pygame.joystick.get_count()):
myjoy = pygame.joystick.Joystick(i)
myjoy.init()
joy.append(myjoy)
print "Joystick %d: " % (i) + joy[i].get_name()
print "Depress trigger (button 0) to quit.\n"
# run joystick listener loop
joystickControl()
# allow use as a module or standalone script
if __name__ == "__main__":
main()
Ok, I try some moves and some help to other vb forums where I really want to convert the code (in underline) to vb.net.
This line is to Arduino joystick servo hack. Its just Im need.
Code:
' Variables needed:
Dim axis As String
Dim pos As Double
Dim move As Integer
Dim servo As Integer
' Ported code
If axis = "X" Then
pos = ???
move = CInt(Math.Round(pos * 90, 0))
If move < 0 Then
servo = 90 - Math.Abs(move)
Else
servo = 90 + move
End If
End IF))
But not I didnt not find some library or function similar in VB.net
Code:
handleJoyEvent(e):
Can some one help?
Or please, tell me the code in VB or C#  to communicate arduino from joystick via serial?
Thanks!
  • Guys, its me again...
    Sorry to borry...but I need help with this.
    [CODE]
    import serial
    usbport = '/dev/ttyUSB0'
    ser = serial.Serial(usbport, 9600, timeout=1)
    #print ser
    def move(servo, angle):
    '''Moves the specified servo to the supplied angle.
    Arguments:
    servo
    the servo number to command, an integer from 1-4
    angle
    the desired servo angle, an integer from 0 to 180
    (e.g.) >>> servo.move(2, 90)
    ... # "move servo #2 to 90 degrees"'''
    if (0 <= angle <= 180):
    ser.write(chr(255))
    ser.write(chr(servo))
    ser.write(chr(angle))
    else:
    print "Servo angle must be an integer between 0 and 180.\n"
    [/CODE]
    This code is more simple:
    I Try to to convert to VB and look like this:
    [CODE]
    Imports Microsoft.DirectX
    Imports Microsoft.DirectX.DirectInput
    Public Class Form1
    Dim RotationX As Integer
    Public Function GetSliders(ByVal servo, ByVal X) As Integer()
    If (0 <= X <= 180) Then
    SerialPort1.Write(Chr(255))
    SerialPort1.Write(Chr(servo))
    SerialPort1.Write(Chr(X))
    Else
    Print("Sorry")
    End If
    End Function
    End Class
    [/CODE]
    My question is, why i have this warning?
    Warning 1 Function 'GetSliders' doesn't return a value on all code paths. A null reference exception could occur at run time when the result is used.
    I understood the GetSliders dont return any value, but I put servo and X why this?
    and this line:
    [CODE]
    [/CODE]
    In google I find this information:
    In the above code there is really only one new keyword: def. def is the keyword used when defining functions. Arguments are passed in paranthesis just like C, and the return statement can't return multiple values. However, since lists, tuples, and dictionaries are basic types they can be returned instead. I'll illustrate this later. A quick thing to note about Python functions: They always return a value. However, if no return value is specified, or you don't use the return keyword, Python automatically returns the value None.
    Ok, so the code similiar in VB.net is the "Function" right?
    Thanks and sorry to borrow!
    VB.NET Shop
  • Hey people!
    I use Iron Pyton to work in VB.net 2010 and I have this windows to show:
    If you see, there are handlejoyevent and joystick control.
    Can I know ou find information about this two event? If I discovery, I
    can find some similar in VB.net write?
    Thaks in advance!!
    VB.NET Shop
  • sharpdevelop has built-in capability to convert between .net languages. Maybe it can do the trick.
  • Another option: Iron Python runs on the .NET framework, if you ran that python code in there, you should be able to call your functions from your existing VB code without having to re-write anything. Its not that much code, but if you get this working you can easily add more external python in the future without having to re-write.
  • I think that it's quite possible
    I can help with this code if you like
    Here's where I think that can be a good start:
    http://www.codeproject.com/KB/directx/joystick.aspx
    http://www.slimdx.org/features.php
    http://code.msdn.microsoft.com/WindowsAPICodePack/Release/ProjectRe...
DIY Robocars via Twitter
Jul 4
Jul 4
Jun 25
Jun 25
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
