Hi,I'm looking to build a DIY UAV for cold weather. I'm in Canada & it's cool-cold for at least 5 months of the year.Is anyone else building for colder climates???? I'd love to pick your brains on what works.
Yes, we flew a telemaster based platform using a MicroPilot autopilot in -20C weather for a search and rescue exercise 30Km from where we launched. Worked well.
temp control using PWM current is a source of noise, be advised.
thermos around barometric sensor will make it more likely to cause troubles, it will depend more on windgusts when its own temperature wil vary more from the actual air temperature. pressure sensors are better left equalized with airtemp.
NiCd bats have wider temprange than NiMh, but come with memory effect and other surprises. Still, they are down to -20C usually.
LiPos are worse at low temp but as they heat themselves better (being used for propulsion), it is sufficient to insulate them thermally. Just try to not boil them in summettime.
Ive heard of people heating LiPos with their own power by wrapping a heating element around it and hooking it to the terminals when it gets to cold for them to work.
www.aerialrobotics.eu/flexipilot/flexipilot-weather-en.pdf
It works, I did some 30 landings in the snow and -20..+5C.
Not funny experience as hands freeze on the controls.
Basically for snow operations, better use pusher
configurations.
You must also get the plane off the car before takeoff for
longer (15 mins) because of barometric sensor drifts, unless
you accept some 10m altitude drift after 15min.
Greg Lewis
Greg@aerialinsight.com
www.aerialinsight.com
configurations.
