confusion in pitch with HKMega V2.5
Hey Fellas,
I dont mean to bore you guys with this probably simplistic problem but I am confusing
myself with this board. The autopilots were a gift from a friend and I can program it fine.
My radio is the Fut. 18MZ. I just use some DJI Flame Wheels for the basic structure
but I use regular 22 mm motors and some 10 Amp Speed opto controllers with BEC.
So a regular quad. But I have built three of them and the last two exhibit the same
problem. Roll is fine and correct. I loaded the 3.01 firmware from the Planner.
I do the compass calibration and it always comes out some large number in
the first digits like 195,-49,-13. or 199, -52,-19. That first digit is always over 150.
the Accelerometers are always good. Radio  cal is good and I go out and fly and
it just flips over either forward or backward. Roll seems to be fine. You can see the
quad lift to the right or left based on the stick input. But I can NOT get it to pop up
straight. I put the 3.01 firmware and one with the 2.5 load and both do the same.
If I reverse the channel it still flips over, And you can see it coming by raising the
throttle .  It must be a simple thing.
I usually build DJI stuff but I have had a blast doing the ArduCopter stuff, but
I just have to get past this simple issue. It might have to do with the Compass
cal, but I cant get to get that number. The hard part is I still have cable connected
and it keeps me from doing a smooth motion when rotating the quad. I have this
same problem with the 2.5 or with the 3.01 load. Thanks so very much for this
forum. A really great place to come learn!!!
  • If you look at the servo monitor window in the Tx are they all moving independently?
    Why not try just resetting the model in the Tx back to default.
  • Appears to be something with my Futaba 18MZ Tx and the 7008SB in using the Sbus or
    the regular mode. I never have problems with Sbus, and its apparent I have something crossed
    up between a regular cable for each channel and the SBus. There is a little COMB window
    next to 5 of the 6 channels in the radio
  • Here is another data point.  the copter acts as if Yaw and pitch are hooked to each other
    or they are in each others input. Its a Futaba 7008SB receiver with the 18MZ Tx. I am perplexed
    But I have done something wrong.
  • Thanks Mike I will try that this afternoon
  • Whenever I get strange things happening with an install I go back into Terminal/setup
    Do an erase
    Then a reset/Y
    and reboot
    Go through the calibrations again from scratch
    It usually does the trick.
    I now do this as a matter of habit whenever I do a firmware upgrade.
  • I'll ask the simple questions first:
    Have you set the board orientation correctly, a '+' or 'x'
    Motor directions?
    Props correct?
    If you run it up holding it (just low throttle) does it react in the right direction when tilted, ie, try to level it's self.
    If you move the sticks do the motors change speed correctly? right roll - rolls right, forward - tilts forward, etc.
    Have you been through the accelerometer calibration?
    When sitting flat and connected to the Mission Planner is the HUD moving correctly when you move the copter.
    When you reload the firmware do you do an erase and reset?
DIY Robocars via Twitter
RT @knightsautoteam: Hi @diyrobocars, we are Orlando's first Autonomous racing club and would love your support. We are hosting our first K…
Jan 20
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #14 - #ParkingLotNerds join us January 15th for #AutonomousRacing #RoboRace ⁦@DAVGtec…
Jan 16
RT @chr1sa: And after that came our races, 50 in all. This battle between these two Russians was the best we've ever seen -- incredible fig…
Jan 16
RT @chr1sa: Before our @DIYRobocars virtual race this weekend, we had a presentation from the team that won the Indy Autonomous Challenge i…
Jan 16
DIY Drones via Twitter
Dec 12, 2021
Dec 12, 2021
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Dec 4, 2021
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28, 2021
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26, 2021
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25, 2021
@gclue_akira CC @NVIDIAEmbedded
Nov 23, 2021
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23, 2021
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23, 2021
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20, 2021
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20, 2021
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9, 2021
