Connect Raspberry PI to Px4
Dear,
I am trying to connect a Raspberry Pi 3 to Px4 Arducopter V3.4
I am following this instruction: http://ardupilot.org/dev/docs/raspberry-pi-via-mavlink.html
My problem is when I connect RPi 3 to Px4 and do the command :
mavproxy.py --master=/dev/ttyAMA0 --baudrate 57600 --aircraft MyCopter
In the manual, 3 files should be sent from Px4 to RPi3 (mav.parm, flight.tlog, flight.tlog.raw). But in my case, mav.parm (a text file with all the parameter values from the Pixhawk) is missing. So I think that why I can not do any command on PX4
I attached a result photo below, is there anyone who know about this problem please support me to overcome it
Regards
Anh
  • Hey bro, check out this:
    http://sammyherring.co.uk/raspberry-pi-3-uart/
    this is a kind of bug from pi 3, follow that instruction could figure out the problem, good luck!
  • Hi Anh,
    I have same situation like you, do you have any improve? I am also using RPi 3. I tried to receive some mav data from pi3`s UART0, but i got nothing. I also tried to sand some another data via UART0, I got the data this time, so the UART0 is work, looks the mav command not work.
