I would like to connect a BeagleBoard-xM to the ArduPilotMega 2560.  Connecting over serial appears to me to be the easiest way.  I see that in the Arducopter code, Serial2 is not being used.  However, tonight I noticed this comment in the optical flow code: "External ADNS3080 OpticalFlow is connected via Serial port 2 (in SPI mode)."  I would also like to use optical flow, in addition to the BeagleBoard-xM.  Can anyone confirm this comment is true?
If this is the case, how do you suggest that I connect the BeagleBoard-xM and ArduPilotMega so that they can exchange data?
Thanks!
  • I am building a quadrotor with object tracking feature. all image processing will be done on beaglebone black. can anyone guide me how can i connect beaglebone black with ardupilot mega 2.5 so that beaglebone can give movement commands to ardupilot? also is it posible?
  • Hi Guys,
    Sorry I have been AWOL.  I got the connection to work just fine using MAVLink between an app running on the BeagleBoard/PandaBoard and the APM board.  Please see section 6 in my attached report for more details.
    paper.pdf
  • Hi Noah;
    I want to do same thing. So, if you could achieve this please give some information about it.
  • +1
  • Noah: were you able to connect beaglebone to ardupilot?
    I can connect it through UART0 from APM to beaglebone through pin21/22 on beaglebone... but the problem is it doesnt works if i unplug the USB and power the board through battery.
    would love to know how you solved the issue.
  • Hi Noah - were you ever able to exchange data between your BeagleBoard and the APM? I'm a student at Georgia Tech and our group is trying to do something similar. Do you have any suggestions?
  • Serial 2 cannot be used without changes to the arducopter code. It is put into spi mode in order to communicate with the analog-digital converter on the IMU shield, the data-flash chip, and the optical flow sensor if available. You could connect another device to this port by using a spare digital out on the apm as a chip select line so you only talk to one device at a time.
    Students at where I go to college did a similar project with the original BeagleBoard. They just connected it using the usb port on the shield (Serial). It worked fine for them.
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
