Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Sad to apm2。
You will need to solder 3-pins of a DF13 6-pin cable to the gimbal controller board as shown above and then plug the other end into the Pixhawk’s Telem 2 port (from Copter 3.3 it should be possible to attach the gimbal to any of the available 6-pin ports)
Found this on storm32 Page@wiki
Can somebody explain the (from Copter 3.3 it should be possible to attach the gimbal to any of the available 6-pin ports) function? Should this work or will this work? Is there a change in how the serial ports can be used?
To be more specific... This passage reads like I will be able to map storm32 to serial5? No dev can tell something about this?
Hi Randy,
I'm testing 3.3RC1 using PIXHAWK and PX4FLOW,
In the release notes, you mentioned "PX4FlOW support in Loiter mode",
However, I just failed to switch into loiter mode indoor.
Can the flow sensor be used without GPS-lock?
Thanks advance for your reply.
Zhang,
Yes, it can apparently be used without a GPS lock but only Paul Riseborough knows how. I know he's planning on writing up a wiki page but he's knee deep in EKF investigations around AC3.3. I'll ask him to post the parameter changes here if he can.
Trying to take advantage of the new retractable landing gear features. Running a Chinese retract set on a 600 hex on a camera rig.
Any tips/suggestions on how to configure the wiring and parameters? In lieu of the gear mode is there a simple pass thru I can use to control the gear?
Look few pages back.. The dev already wrote a description
Yep, here: http://diydrones.com/xn/detail/705844:Comment:1973458
I have read Rob's comment but I am not clear whether the gear will deploy only in Land or RTL with throttle failsafe or will the gear deploy with Land or RTL regardless of failsafe condition..?
It should deploy regardless of failsafe. But it does NOT deploy based on altitude! It only deploys in Land mode, or the final stage of RTL (which is basically land mode).
If you are landing manually in Loiter mode, it will NOT auto-deploy. Nor will it auto-deploy if you are RTL'ing into a hill, etc.
