Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • In mission planner, on the "flight data" screen, below the hud, there are some tabs. The 7th one is "DataFlash Logs" on that tab is a button "Download DataFLash Logs Via MavLink".
      You should be able to download logs by clicking it.
      • Parachute testing:
        Ok flight data screen - route worked, thanks. Always used terminal but that is easier.
        I made now some new tests and found that copter needs to be shaken (take off just a little off the table) before eject works. I got "parachute released" when copter throttle was above half and copter lifted from table. Lower throttle didn't activate possibility to eject, ie. gave too low message.
        Is there some rules for checking take off even altitude check is disabled?
        If so, that is good to add to Wiki at "testing the chute" section. In general I use every now and then eject with my camera workhorse copter on the ground with throttle raised only a little. This is just random check that motor shut down works and nothing is changed on mixing or settings. I'd prefer to have a change to eject manually what ever the flight situation is. Automatic eject should have strict conditions.
        Logs are here, check latest one (uploading slowly): https://www.dropbox.com/sh/kkj603nsciv3u1k/AACLBcavjFC45Y7DUhfvtVt1...
        Another note: eject ON PWM is active only short time, perhaps a second or so. It's good to be adjustable, or few seconds longer. This might be now too short for servo, or for our Fuse blow if parachute battery is too optimized and really flat.
        Third note: Angle detector doesn't react if lean happens quite slowly.
        This our test parachute test copter has major vibrations for sure and it may affect. But I think that could be the case on motor failure with any copter.
        I keep testing more later. If there is something you developers or anyone wants me to try, please advice me. This copter is made for risk scenarios and have dual parachute triggers (Pixhawk / direct radio) just in case. Dual parachutes is possible if needed.
        Henri
        Skycat.pro
        logs
        Shared with Dropbox
          Henri, I'll reply at the latest part of this thread rather than back here on page 42.
  • Has something changed in relation to GPS locks? I was out today for a test flight. Telemetry was telling me I had a GPS 3d lock but if I tried to arm in poshold it failed with a GPS lock required warning. Similarly if I took off in stabilise and tried to switch to poshold it wouldn't let me. Logs from one of the flights are here. https://dl.dropboxusercontent.com/u/564974/3.3-rc3%20log.zip
    • I had similar problem and received the following reply yesterday:
      http://diydrones.com/xn/detail/705844:Comment:1985502
      in essence:
      EKF check gives the same pre-arm messages (need 3D lock) but it refers a different, newly introduced pre-arm check.
    • Did you power and an wait for a GPS lock tone before arming and lifting off?  That is something new to version 3.3.
      • I powered it on and left it for about 20 minutes at one point to see if it would get better but it made no difference, I had about 6 satellites on average and a HDOP <2. The tower app indicated a 3d lock but when I tried to arm in poshold I got the GPS lock error none the less.
    • Hello Graham, do not remember exactly but a lot has changed and it is more difficult to get a fix good enough for pixhawk to let you arm
  • Hello ,
    I use two GPS in auto mode in 3.3 rc3.
    GPS0 - from 3dr and GPS1 - from China.
    GPS0 see 10 satellites. GPS1 see 20 satellites.
    I understand that Pixhawk use GPS1 because GPS1 see more satellites, than GPS0.
    I have 3 questions:
    1. What happens if the power off on the GPS1? Pixhawk switch automatically to GPS0?
    2. If received signal is wrong from GPS1 (eho from wall) and received signal is truth from GPS0, Pixhawk it can determine?
    3. EKF compares signals from two GPS connected to Pixhawk?
    Cheers,
