Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • With RC5 I now get the error message "Error EKF POS VERT AGL" all the time.  The quad (550 H Frame) flies fine in loiter, position, stabilize.
    Steve
    • thanks pal for the feedback. It seems that this error does not affect the quad. though when using the Mission Planner, this error prompt is quite annoying :D hopefully this will get fix soon. thanks again!
  • I'm using MP1.3.27 build 1.1.5620.38044 and updated to rc5 and after that I did a "reset to defaults".
    I choosed frame and then I tried to calibrate accel, the program steps from place level to left and then directly to right?
    So I am unable to do the calibration...
    I have uninstalled MP and reinstalled it and the same with the FW but with the same result?
    • I'm getting the same, did you manage to figure out the root cause yet?
      • Seems to be fixed in rc6
    • I tried with 3.2.1 and then the calibration of accel  was OK so it seems to be rc5, rc4 was OK.
  • I'm also using Mission Planner is 1.3.27 build 1.1.5620.38044
    I get EKF PRED POS HORIZ ABS when I power up but changes to "Error EKF POS VERT AGL when i get a satellite lock
    8 satellite hdop 1.8
    I have just flown and everything seems to be working ok, tried loiter but not RTL
    • thanks for the feedback. I stll haven't flow yet because I am still getting more feedback about these errors. Hopefully such errors wont affect the flights, it would be troublesome if it would cause a fatal crash..
  • I just loaded 3.3-rc5 and I'm getting "Error EKF POS VERT AGL" continously
    • i got that error before I  update to the latest beta firmware of Mission Planner. But now the error prompt just changed to EKF PRED POS HORIZ ABS. THe quad arms with no probs. But I am a bit concern with these EKF errors..
      the version of my Mission Planner is 1.3.27 build 1.1.5620.38044
