Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Leonard,
Thx for the great explanation and for me the pixhawk is indeed way ahead of other pilots and if not it will be (on some areas) with this great support from the developers
When the new (mini) pixhawk is released I will sure try it on a mini acro fpv racer
There are quite a few "mini" out already. They are called Pixhawk Lite. And they work really well.
yes i did but it doesn't took effect..
Have you tried to change it via the full parameters list? It should let you set any value i think and keep it.
Is pixhawk with 3.3.x always using EKF or still as a option controlled with AHRS_EKF_USE ???
Ok found it "In Copter-3.3, this feature is forced to “1” and cannot be changed"
What the link to Copter-3.3? Thanks in advance.
http://firmware.diydrones.com/Copter/
Thank you, This is the link to firmware. But where can I read about all new (and old parameters)?
I read a post by Randy saying the PPM Channel Mapping issue would be resolved before 3.3 went final. Does anyone know if that is done?
It's done. I am flying with it - it works well.
