Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Do you have a log? That'll tell you what the warning is.
      • I'm able to extract the log, but I get this when I try to load it in APM Planner to look at it:
        Error preparing inserttable: insert or replace into 'GRAW' (idx,"TimeMS","WkMS","Week","numSV","sv","cpMes","prMes","doMes","mesQI","cno","lli") values (?,?,?,?,?,?,?,?,?,?,?,?); Error is: table GRAW has no column named cpMes Unable to execute statement
        • If you get corrupted logs over mavlink then pop out the SD card and read directly onto your computer
          • I'm getting this as well...
  • So if you're getting EKF variance messages you're pretty much done with 3.3 until it's fixed?  Reason I'm asking and I know it's beta, but the autotune works so well!  After autotune in 3.3, none of my big units have ever flown this well.  Before I didn't even bother with autotune and they were flying like crack addict squirrels lol!  But all the muti's are used for mapping.  If I'm half an hour into a scan and I get dropped out of Auto mode that would be lame.  I presume that's what going to happen with the EKF variance problem?  Can I autotune in 3.3 and copy to back to 3.21?  Or are the gains weighted differently.  Anyhow, great job on the autotune!
      Hi Shaun,
      Thanks, I am glad you are enjoying autotune!! rc6 is a little better still.
      The big difference between 3.2 and 3.3 is the yaw controller. I have added filtering in there to handle the physics of copters properly.
      I can't really answer your EKF question but you should be able to apply your roll and pitch autotune results to 3.2. There are a couple of changes that may make them a little less than perfect but I am not sure.
      • Hi Leonard!
        I again tuned yaw on OCTA with the 18x6.5 props. Twice tuned, both times were these:
        1. aggr_tune =0.09: stab yaw= 5.209 , rate yaw p= 2.0, i= 0.2, d=0.0
        2. aggr_tune =0.07 stab yaw= 5.44, rate same pid.
        I low aggr tune and stab yaw is upper.
        When released rc6?
          Hi Aleksey,
          I am not sure what you are telling me with your tuning results. If you have a problem could you also provide a tuning log.
          RC6 should be out by the weekend.
  • I'm a latecomer to beta testing v3.3.
    I've had many successful flights with v3.2 but with v3.3rc5 I often cannot get it to arm. APM Planner says it needs a "3D Fix", yet I have 8 or more satellites and hdop of 1.6 - 1.9. I've even cranked up the HDOP threshold to 400 (i.e., 4.00)
    First thing this morning I did get it to arm (after quite some time) so I successfully did the autotune process. After landing I changed the battery and tried to do another flight but couldn't get it to arm. I've had "prearm chk mask" = 1 (everything) so I tried to exclude only the GPS check but APM Planner doesn't seem to let me upload a number greater than "127" (and unsigned char??).
    Could the "Need 3D Fix" message be generated by the failure of something else beside the GPS? I'm using a HKPilot32 (Pixhawk clone) with Ublox M8N gps on a F450 frame.
    Can anyone shed some light on this?
    • Depending on your fpv transmitter frequency, 2.4 being the worst, it can generate a lot of noise and make aquiring sats difficult.
      I like 2.4 for video and ended up using channel 2505, trying different antennas and maximizing separation until the GPS stopped complaining.
