Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
These look normal to me. If it was fine in flight I doubt the gyro is the issue.
landing in RTL seems to suffer from position adjustment errors IMHO when drone gets really close to the ground, then it catches at the ground with landing gear and flips over. sometimes it happens, sometimes does not.
it actually happened today once to me, after not happening for quite a long time. it helps to have a mapped emergency engines stop function to one of a switches on the TX so you could kill motors at once if you see this dance started happening. .
update MP to newest beta version. it is function code 31. I assigned it to lower right switch on taranis, a flip switch. it is immediate. it is extremely helpful. if you hold it up for 2 sec it disarms the drone.
Roger,
I wasn't sure but just checked and it looks like we did manage to update the ch7/ch8 wiki page to include this option including a video!
RC7.
This hexa aircraft act like an angry mosquito on steroids!
It did starts this ekf-2 error. Don't know (what it is) or why.
bin file included.
Just for info: Flew without any vibration on 3.21.
Did not even take off. As soon as a bit of throttle is applied, it want to go up very very nervously!.
Thank you in advance.
bin file for above
2015-06-30 08-20-04.bin
Sorry for so many posts. Here is the download link to the log mentioned. It was just outside the native upload limit.
http://1drv.ms/1Hr8iaR
Just to compare Artem's (correct) interpretation of the IMU data, I checked out the new VIBE message. It also shows the vibes are many times higher than my IRIS and more seriously there's a lot of clipping on both the primary and secondary accelerometers.
no wonder your copter jumps up and down :) your vibes are waaaay over the head.... check all the bolts, make sure that your frame is structurally intact and that your props are balanced.
If using case, make sure your board is not "dancing" inside or if the whatever mounting option you use did not come undone.
305
306
307
308
309
of 449 Next
