Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          Craig,
          Ah ok good.  At least some of these are "known issues" and all related to the log analysis tools rather than the logs themselves.  We have a fix for the Log Analyser but it needs to be tested and then the MP will need to pickup the change.  I'm not too familiar with Kev's log analyser tool but I suspect it needs changes as well to deal with AC3.3 log file format changes.
          The size of the logs is temporary. We've increased the IMU logging to 400hz for beta testing.  For the official release we will reduce that to 50hz and the logs will be 4x ~ 8x smaller (the IMU data is a large percentage of the total log size).
  • I think we should take this EKF dude behind the wood shed for a little talk.... lol
    • LOL !
    • Thanks for the replies.  Now I know what to focus on I will try a newer GPS model (when it arrives) and see what happens.
      Richard, I am not complaining about the code and I understand it is Beta software.   I have been working on this on my own and am not just putting stuff up every time  I get stuck (which, until now, has both been rare and I have been able to fix).
      That being said,  I thought the idea of beta testing is to both get reports of good results and bad ones.  I don't have a wood shed but I am happy to have a talk as long as you have something useful to to say that will help me out!!   I don't mind being told that I am doing something stupid if it fixes my problem.  So far all of the advice has been informative and constructive while helping me to narrow down possible causes.
        I think Richard is just kidding around and he's picking up on my weariness re the EKF.  The EKF is a fine piece of software but is more complicated than the older DCM/inertial nav and is proving a challenge to get exactly right and there's still some learning we need to do in the wider dev team in how it's acts.
        Definitely appreciate both good and bad reports re AC3.3 and we're close to the finale so we should expect it to perform very well at this point.
  • Hi Randy,
    Thanks for the info, I really appreciate the effort.  I have another GPS on order and will see if that make the difference.
    I have also previously tried replacing all of the GPS cabling and running the system removed from the frame (to get away from interference)
    All of my GPS units are 3DR LEA-6H with the original config on two and one of them I have reloaded the config a few times. When plugged into uCentre they all seem to work correctly with no problems.
    My next question would be, should I be able to fly in STAB or ALTHOLD without the EKFG Error?  Do I need a full 3D position fix every time I fly?
    Thanks again for the reply and it gives me more insight than I could obtain on my own but I have learnt a lot about the code etc in the process.  I am constantly in awe of the work you guys do and hopefully, one day I can actually be able to contribute something useful!
      Alex,
      You don't need a full 3D lock if you're only flying in stabilize or AltHold.  Ideally bad or missing GPS data shouldn't affect the attitude estimates but I'll ask PaulR to confirm.  If bad/missing GPS does affect the attitude then it's something we should fix.
  • I'm using rc7 and it's almost all fine, i have only troubles when i try to start without GPS signal in mode stabilize.
    The led is flashing blue then when the motors are startet the led starts flashing yellow/red. The copter then doesen't fly very good and it's also possible it's losing level.
    is this a known issue ?
    • I have had this happening since 3.3.2 came out.  I think randy said that EKF is using GPS to determine position even though GPS is not used in Stabilize mode.
      The copter flies fine except you may not have a good home position.
      Doesn't always happen but sometimes.
    • No. Can you attach a log?
DIY Robocars via Twitter
RT @a1k0n: @DanielChiaJH @diyrobocars @circuitlaunch Here's my car's view of that race. About 8.4 second lap times for laps 2 and 3... both…
Monday
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
Sunday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
Saturday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
Saturday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
