Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • That's great to know about the geotagging!  I hate relying on Pix4d as it can fail sometimes.  Any Idea when the driver for the LLv2 will be out?  Ordered one last week.  Would be really nice to incorporate this into auto mode allowing us to set a minimum distance between objects on the ground and the copter.  Basically simple obstacle avoidance.  When making complex flight plans for photogrammetry or lidar our elevation data can be way off.  This would make a great backup to good flight planning.  For example, if we could set a minimum 20m safety zone and the mission is at 100m but there's a rise in the terrain not seen in the elevation graph the unit wouldn't crash lol!  Sounds pretty useful.
          The lidar-lite-v2 driver is on it's way and will make AC3.3-rc9 but using it during AUTO won't be available until AC3.4 I'm afraid.
  • Could someone point me to a thread or just know off hand the differences between using autotune_aggr .1 to .05?  Feeling a little stupid here, but I don't get it lol!
      Shaun,
      I quizzed Leonard about the meaning of the AGGR parameter and added a note to the wiki's autotune page.  Not a stupid question for sure 'cuz the answer's hard enough to understand when it's right in front of you.
      AUTOTUNE_AGGR : Should be in the range of 0.05 to 0.10. Controls the threshold for D-term bounce back and P-term overshoot. This affects the tuning noise immunity (a higher value is more tolerant to flex in the frame or other disturbances that could trick the tuning algorithm).  High values also leads to a tune that rejects external disturbances better.  Lower values result in a tune that is more responsive to pilot input.
      • Yup, I read that...  Not helping much lol!
          Hi Shaun,
          The simple answer is a successful tune at 0.05 is better than a tune a 0.1. It is faster and more stable.
          If the tune is not successful increase it to 0.1. This will be more tolerant to unwanted moments and wobbles in your copter and more likely to succeed.
          Signs a tune has not worked are:
          1. The D or P terms have went to minimum. ( 0.004 for RD, 0.01 for RP, 0.5 for SP, and 1.0 for the filter frequency)
          2. The copter flies worse after the tune.
          3. The copter is generally sloppy to fly and doesn't make you feel like it assertively holds it's attitude.
          • That's a great answer!  Thanks!  I'll be autotuning a 1300mm X8 with U8 motors today.  Start at .05 and see how it does.  We now have 6 units running 3.3rc8 now with great results, ranging from 680mm X8's to 1300 X8 frames (a few hex's in there as well).
    Problem on optical flow with APM rev 3.3rc8
    Dear Friend,
    in last week we are testing the APM 3.3rc8 on VR Brain 5.2 , we are checking all nuttx driver and advanced functionality like Optical Flow loiter and lidar terrain following functionality.
    So about the lidar we are very happy ... did a lot of test and all work fine as you can see in this video:
    https://youtu.be/XXTeOogVd8k
    After the test of alt hold we start to evaluate optical flow , follow the wiki instruction did the first fight well and check the log ... then activate the optical flow , armed the drone in stabilize , because in loiter the pre flight check tell that is not possible without 3D fix .. then switch in loiter and try to take off. When i'm taking off i check if the command on roll and pitch work well but it don't work ... don't move the drone ... only throttle work if i re switch to stabilize i re take the control on pitch and roll .
    What could be the problem ? Are there some guys that sucessfully check this release of firmware with Optical flow ?
    Thanks in advance
    Roberto
      Roberto,
      Thanks for giving this a try.  I know Paul got it working (as did some 3DR Solo people) so it *did* work but I haven't tested it personally.  If you have a dataflash log we can ask Paul to have a look.
      Good to see the althold with lidar working well at least!
  • Had finally time to test an AutoTune on RC8, all my previous problems are gone and the Quad preforms really well after AutoTune
