Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Wes,
It is my understanding that the yaw controller has changed in RC 3.3. Your Yaw Rate P is currently set to .2 from you r9.bin file. My new Rate P settings in 3.3 are often as high as .8 from ~.2 in RC3.2. I would recommend you re run your autotune on the yaw axis and probably all other axis as well to see if that helps.
Also you are having clipping due to vibrations on your acel just prior to the rotations starting so there is likely a vibration problem to be solved as well.
On a side note it looks like you've managed to spin 8 times if the logs are correct. I bet that was a fun thrill ride. Hope you can figure it out.
Would you auto tune a multi that is yawing out of control?
When I loaded 3.3 this time I loaded rover first to clear all settings so the 3.3 install would be clean. Default setting.
This weekend I spent several hours balancing props to a gnat's hair starting with a new set. I remounted the FC using small squares of Kyosho dampening gel- the green 3/16 thick type.
Vibration levels dropped from +-3 to +-1. If I still have a vibration issue it would have to be a failing component, motor/ esc/ FC.
I have an extra Hawk FC so I am going to try that first.
I just tried one test flight after moving to 3.3-rc8. I was under oak trees in the backyard so I didn't do much but it seemed very stable. I have a M8N and it seemed to toilet bowl some in Pos Hold. It took several attempts to get a good compass calibration that pointed where the quad does.
Auto analysis reports many things not logged in spite of Log_Bitmask being set at 43006.
What should the bitmask be set to? And are there other parameter changes that might help the M8N?
Log attached.
2015-08-12 19-57-23.bin
Greg,
Thanks for testing. The flight looks pretty ok - hard to see the toiletbowling so maybe that's another log or perhaps it's very subtle. The heading estimates from DCM and EKF appear to stay within 10degrees of each other and the ATT's ErrYaw is always quite low (0.15) so it shouldn't be toilet bowling much.
I don't have any extra advice for the M8N, perhaps others do.
Using 3.3rc8 I'm getting and error in Mission Planner - Error Compass Variance
Seems like others have seen this issue, but I've not found a solution yet in this thread. Is there a fix for this problem, or is this recognized as a problem yet?
Thanks,
Scott...
If you have some dataflash logs that would be good as well. I've seen this compass variance come up a few times as well on the thread but so far, no logs! Best to set Logging-while-disarmed checked in the LOG_BITMASK selector in MP.
log file
Randy, hope this helps. See embedded link to my log file... Also attempted to attach...
Scott...
2015-08-17 20-35-58 5.bin
When you get your error compass variance messages usually your pixhawk will have a flashing yellow LED. Pick up your copter and move it a little bit. This usually fixes the error and allows the pixhawk to arm and continue a normal flight. This is the only workaround I have found for this problem aside from removing power and plugging it back in until a fix can be produced.
When do you plan to fix this? This is easy. Annoying to see it every time ...
Yah it's been that way for a while and should be an easy fix for Mr. Osborne but I have a feeling he has his hands full just keeping up with all the changes in the RC firmwares :)
