Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Did you do an auto tune with rc9?  What improvements did you notice? I still have 3.2 and it's a little squirrelly in the wind.
  • today I had several flights with -rc9.
    Amazing! so extreme smooth and stable!
    Only thing i recognize is, that Lidar not reacting during flight. I mean Sonar Range shows correct Value but if I'm flying over obstacles there is no reaction. Does anything changed between -rc8 and -rc9 regarding the rangefinder /lidar?
      Andre,
      There shouldn't be any changes to the control logic used for the sonar.  There's a change in the the Lidar-Lite-V2 is now supported but that shouldn't have had any effect.  If you can provide a dataflash log we can have a look.  Txs for testing!
      • Hi Randy,
        Thank you for have a look on the logs. One is with rc8 and working Lidar and one with rc9 no Lidar working. But in the Missionplanner the sonar shows correct value. I'm using the Lidar V1 (Build Feb15) with PWM.
        AC33-rc8_Lidar-ok.bin
        AC33-rc9_lidar_notOK.bin
        Dropbox - Error
        Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
        • I just had another flight and now the Lidar is working again. I don´t know why. I changed nothing!
          Btw. It was very windy (12016KT gusting 24KT)) and the copter hold the position and was still extremely stable in the Air!
          Thank you for that amazing Code!
  • Still getting "Error Compass Variance" and "BAD AHRS"
    Randy can you take a look at the attached file and see if it gives you any clues?
    Thanks,
    Scott...
    201508172035585.bin
      Scott,
      The compass values are very odd.  They start off extremely high and then drop after about 20 seconds.  Both compasses seem to be affected which points more towards a physical change in the environment rather than a software issue.  Can you think of anything on the vehicle that might be causing a big increase in the magnetic interference for the first 20 seconds?
      Also which flight controller are you using?  I ask only so we can start to build up an idea as to whether it's related to specific flight controllers or not.
      3702588959?profile=original
      • I'm using a pixhawk lite as well... With a 3DR GPS / Compass
        Is it possible to do the MAG graphing in real time?
    • I'm getting the same thing on 2 different hawk lites, both only using the onboard compass.
  • I made two short testflights with rc9, to test batt_failsafe with AUAV-X2.
    Batt_FS set to 10,8V and RTL.
    At first flight flightmode was PosHold when Batt_FS triggert, but it switched to LAND instead to RTL.
    The distance was >10m and hdop was 0,87.
    I switched to STAB to stop landing, later i trigger RTL manualy.
    At second flight flightmode was Drift when Batt_FS triggert and it switched to RTL, as it should be.
    Also for me the problem to detect "usb_connected" with AUAV is not solved.
    The bit in POWR/Flags is all the time "1" and i found at least these parts in the firmware that react on these bit:
    ekf_check.ccp
      // return immediately if motors are not armed, ekf check is disabled, not using ekf or usb is connected
        if (!motors.armed() || ap.usb_connected || (g.fs_ekf_thresh <= 0.0f)) {
    motors.ccp
        // check battery voltage
        if ((g.arming_check == ARMING_CHECK_ALL) || (g.arming_check & ARMING_CHECK_VOLTAGE)) {
            if (failsafe.battery || (!ap.usb_connected && battery.exhausted(g.fs_batt_voltage, g.fs_batt_mah))) {
    sensors.ccp
        // check for low voltage or current if the low voltage check hasn't already been triggered
        // we only check when we're not powered by USB to avoid false alarms during bench tests
        if (!ap.usb_connected && !failsafe.battery && battery.exhausted(g.fs_batt_voltage, g.fs_batt_mah)) {
            failsafe_battery_event();
    Or the bit thats recorded in the Log not the same?
    2015-08-22 11-48-34.bin
    2015-08-22 11-56-47.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702076045?profile=original
