Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Thanks Roberts looks good!
  • 3.3-rc9 tested today.... amazing... congratulations.
    More than them 10 battery packs (3 quadcopters)... more than 20 RTLs, and more than 30 minutes in Poshold (rock solid).
    3 sizes of quadcopter tested, and 3 flight boards (Pixhawk, FixHawk and Navio+ from Emlid)
    The best release tested.
    And tested with wind “medium to high”…
    • Hi Robert.
      Would be nice to know these sizes of these 3 quads you're mentioning.
      Would help perceive scaling.
      Thank you
      Henri
    • Did you do an auto tune with rc9?  What improvements did you notice? I still have 3.2 and it's a little squirrelly in the wind.
  • today I had several flights with -rc9.
    Amazing! so extreme smooth and stable!
    Only thing i recognize is, that Lidar not reacting during flight. I mean Sonar Range shows correct Value but if I'm flying over obstacles there is no reaction. Does anything changed between -rc8 and -rc9 regarding the rangefinder /lidar?
      Andre,
      There shouldn't be any changes to the control logic used for the sonar.  There's a change in the the Lidar-Lite-V2 is now supported but that shouldn't have had any effect.  If you can provide a dataflash log we can have a look.  Txs for testing!
      • Hi Randy,
        Thank you for have a look on the logs. One is with rc8 and working Lidar and one with rc9 no Lidar working. But in the Missionplanner the sonar shows correct value. I'm using the Lidar V1 (Build Feb15) with PWM.
        AC33-rc8_Lidar-ok.bin
        AC33-rc9_lidar_notOK.bin
        Dropbox - Error
        Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
        • I just had another flight and now the Lidar is working again. I don´t know why. I changed nothing!
          Btw. It was very windy (12016KT gusting 24KT)) and the copter hold the position and was still extremely stable in the Air!
          Thank you for that amazing Code!
  • Still getting "Error Compass Variance" and "BAD AHRS"
    Randy can you take a look at the attached file and see if it gives you any clues?
    Thanks,
    Scott...
    201508172035585.bin
      Scott,
      The compass values are very odd.  They start off extremely high and then drop after about 20 seconds.  Both compasses seem to be affected which points more towards a physical change in the environment rather than a software issue.  Can you think of anything on the vehicle that might be causing a big increase in the magnetic interference for the first 20 seconds?
      Also which flight controller are you using?  I ask only so we can start to build up an idea as to whether it's related to specific flight controllers or not.
      3702588959?profile=original
DIY Robocars via Twitter
Saturday
Saturday
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
May 8
May 8
