Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Wow, Arducopter is getting better every day!
    If I recall correctly WPNAV_UP and _DN used to control the climb rate in althold, this no longer seems to be the case in v3.3, what controls it now?
  • Hi Greg,
    Sorry about your crash....
    I had problems with Qbrain in other platforms (32 bit boards.)
    I spent one month to understand the problem….really hard….…. After more than 20 crashes, I simulated the problem on the ground …. With physical support one axis platform
    And the problem occurs without “loops” too…. With fast commands
    So.... maybe is a similar problem.... “frequency”… I don’t know…
    and with old APMs boards no problems....
    Video with Q Brain (look the video description) 1 year ago….
    https://www.youtube.com/watch?feature=player_embedded&v=yKyrdje...
    Video afters change Q Brain
    https://www.youtube.com/watch?v=sRT8Hpk0kqU&feature=player_embe...
  • Looking at the Alt hold performance on a breezy day for RC10 it looks like the Alt graph line is following the DAlt better than the BarAlt. does this mean the accelerameters are out performing the Barometer under these conditions or is it an avalible trust issue making Alt look better than Baro Alt?
    What could be done to improve the alt hold in this case?
    3702084933?profile=original
    Just for reference I will post the IMU, Vibe and RCO graphs.
    3702084951?profile=original
    3702084673?profile=original3702084690?profile=original
      Hi Wes,
      DAlt is what the controllers are being told to do. Alt is the estimated altitude the controller is using and trying to make equal to DAlt. BarAlt is the raw output from the Baro before it is combined with the accelerometers.
      I believe we can do better in this area than we are currently.
    Trent,
    I'm really not aware of any changes that would cause that kind of behaviour.  As far as I know when the throttle stick is moved just above the top of the deadzone (for example) it will command a very small climb rate, not 20%  We can look into this but the log would be good to see first when you get a chance to upload.
  • This reply was deleted.
      Hi Greg,
      Sorry to hear about your burnt ESC. I don't believe there is anything that has changed that could cause this to happen.
    • @ Greg
      I believe that when you land and disarm you "accept the auto tune" and these values will be used onward. (this is why some people, including myself, just do one axis at a time.)
      You said " Decided to land and disarm due to low battery warning." So good or bad you saved the new PID values at that point.
      I could be wrong but it worked that way until RC-8 or 9.
      Perhaps you could place back your saved parameters before this auto tune and do one axis at a time.
      Henri
        Hi Henri,
        Autotune only saves if has completed the tune. That means it needs to successfully complete all requested axis before it will save the tuned pids.
        • @leonardthall
          Please could you confirm:
          example:
          Bitmask: 0:Roll,1:Pitch,2:Yaw
          VALUE MEANING
          0 None
          1 Roll
          2 Pitch
          4 Yaw
          If I select only the roll axis (1) to be auto tune. Then subsequently take off in alt hold and activate autotune until it finishes this axis, Following land and disarm. Is the new PID for this selected roll axis stored or not?
          Thank you.
          Henri
