Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
auto analysis has to be fixed in mission planner. It's something Mr Osborne and whoever else is working with him needs to address, but I'm sure, just like with Kev's Log Analyzer, with things being such a moving target right now we are going to have to wait until the final hits and then they can catch up :)
I tested AC 3.3 RC10. This is a very stable release.
And I wanted to draw attention to the following:
1. Upload the firmware to Pixhawk AC 3.3 RC10 will be better if the first from AC 3.3 RC 9 down to AC 3.2.1, and then up to the AC 3.3 RC10
2. Then need to check all the major parameters.
And they are need to be rewritten.
2. I do not use the automatic tuning. Better to use the manual settings for test flights.
3. Very important buttons 'Calibrate Level" It is advisable to use prior to each flight.
4. I'd like to ask to make the possibility of setting on or off the Audio Indications in auto mode. I can set the switch, but it is better to do it programmatically.
My first the test here:
Stabilize mode : https://www.youtube.com/watch?v=meYPmOkk6yM
Auto mode : https://www.youtube.com/watch?v=UXIEqR_i45k
As one fellow reminded me lately, this will do the reset as well:
Saves some time;-)
Thanks, I'll try it.
Yes, I agree with Alex and Gervais and created a little wiki page with the three possible methods.
Thanks for consolidating the info so writing the page was easy.
Sorry if this is repetitive (artifact of using a single thread for all feedback regarding this release vs. something threaded like APM 3.3 Forum I wish we could migrate to):
I have found mixed reports of being able to connect the RSSI port on a FrSky receiver such as X8R to the sbus port on a Pixhawk, then setting RSSI_PIN to 103 to get RSSI input. However, other reports suggest this must be connected elsewhere in order for it to work with OSD, and yet others suggest PWM RSSI input has been implemented but will only be merged "in a future release". Is 3.3 that future release? I tried it and got odd values in the 90% range seemingly regardless of where I put the radio, and even if the radio was off, so I suspect either it is not implemented.
I have seen reports of others doing this without a filter to convert the PWM to analog, however, so I thought I would ask. Can RSSI out on FrSky receiver report PWM RSSI to Pixhawk, and can it be viewable both in Mission Planner and OSD? Thanks all.
I'm using it with the RSSI filter as per wiki.
I have a question about Autotune.
I just ran it again, this morning, just to prove this point. It was executed twice before, on a day with no wind, same conditions as today. files 1 and 2 were on same day, file 3 was done this morning.
I specifically wonder why roll values deviate so much every time and it seems that file 3 is close to file 1 again in roll values.
Here is a comparison between file 2 and 3, listed below. File 2 would be a PRE_TUNE one.
Would it be possible to comment on what is actually means when autotune produces such deviation every time and how it would make sense to adjust those values manually?
I cannot think of anything else better than to run this autotune like, 10 times on the same battery type so AUW would be exact same and motors fed same current and then get average value for each parameter and use it for a permanent tune, as I am out of ideas.
Is there any way to improve accuracy of this process? What can be done? Would it help for a tuning logic if we had a set of parameters to identify type of motors and AUW of the vehicle? I am just lost of where this deviation of after-tune values gets from.
Comparing files after-tune.param and PRE-TUNE.PARAM
***** after-tune.param
ARMING_CHECK,127
ATC_ACCEL_P_MAX,43890.22
ATC_ACCEL_R_MAX,118759.8
ATC_ACCEL_Y_MAX,19387.29
ATC_RATE_FF_ENAB,1
***** PRE-TUNE.PARAM
ARMING_CHECK,127
ATC_ACCEL_P_MAX,50821.42
ATC_ACCEL_R_MAX,70294.46
ATC_ACCEL_Y_MAX,19701.48
ATC_RATE_FF_ENAB,1
COMPASS_MOTCT,2
COMPASS_OFS_X,-106.1927
COMPASS_OFS_Y,-30.84122
COMPASS_OFS_Z,24.71892
COMPASS_OFS2_X,74
COMPASS_MOTCT,2
COMPASS_OFS_X,-111.8069
COMPASS_OFS_Y,-32.53017
COMPASS_OFS_Z,15.17129
COMPASS_OFS2_X,74
GCS_PID_MASK,0
GND_ABS_PRESS,101040.5
GND_ALT_OFFSET,0
GND_TEMP,28.81843
GPS_AUTO_SWITCH,1
GCS_PID_MASK,0
GND_ABS_PRESS,101103.1
GND_ALT_OFFSET,0
GND_TEMP,24.19114
GPS_AUTO_SWITCH,1
INS_ACCSCAL_Z,0.9895147
INS_GYR2OFFS_X,-0.02705187
INS_GYR2OFFS_Y,-0.1423247
INS_GYR2OFFS_Z,-0.06322701
INS_GYR3OFFS_X,0
INS_GYR2OFFS_X,-0.02742356
INS_GYR2OFFS_Y,-0.1415454
INS_GYR2OFFS_Z,-0.0474136
INS_GYR3OFFS_X,0
INS_GYRO_FILTER,20
INS_GYROFFS_X,0.004249442
INS_GYROFFS_Y,0.01446475
INS_GYROFFS_Z,0.00545186
INS_PRODUCT_ID,5
INS_GYRO_FILTER,20
INS_GYROFFS_X,0.005726107
INS_GYROFFS_Y,0.01684802
INS_GYROFFS_Z,0.005123362
INS_PRODUCT_ID,5
RALLY_TOTAL,0
RATE_PIT_D,0.01500276
RATE_PIT_FILT_HZ,20
RATE_PIT_I,0.2504629
RATE_PIT_IMAX,2000
RATE_PIT_P,0.2504629
RATE_RLL_D,0.004
RALLY_TOTAL,0
RATE_PIT_D,0.01324288
RATE_PIT_FILT_HZ,20
RATE_PIT_I,0.2561696
RATE_PIT_IMAX,2000
RATE_PIT_P,0.2561696
RATE_RLL_D,0.004
RATE_RLL_FILT_HZ,20
RATE_RLL_I,0.09393342
RATE_RLL_IMAX,2000
RATE_RLL_P,0.09393342
RATE_YAW_D,0
RATE_YAW_FILT_HZ,1.386948
RATE_YAW_I,0.07207587
RATE_YAW_IMAX,1000
RATE_YAW_P,0.7207587
RC_FEEL_RP,50
RATE_RLL_FILT_HZ,20
RATE_RLL_I,0.07115527
RATE_RLL_IMAX,2000
RATE_RLL_P,0.07115527
RATE_YAW_D,0
RATE_YAW_FILT_HZ,1.388439
RATE_YAW_I,0.07012143
RATE_YAW_IMAX,1000
RATE_YAW_P,0.7012143
RC_FEEL_RP,50
SR3_RC_CHAN,2
STB_PIT_P,4.837482
STB_RLL_P,9.45916
STB_YAW_P,4.601859
SUPER_SIMPLE,0
SR3_RC_CHAN,2
STB_PIT_P,4.477704
STB_RLL_P,3.592907
STB_YAW_P,4.450249
SUPER_SIMPLE,0
after-tune1.param
after-tune2.param
after-tune3.param
Hi Paul,
There are two measures that tell you which is the better tune, STB_XXX and ATC_ACCEL_X_MAX. When comparing two tunes look at which one generated the highest values. That will be the better tune.
Looking at the two tunes for roll above I can see the tune that gave you the PRE-TUNE.PARAM. I can't tell you why the roll didn't run well in the PRE-TUNE.PARAM but you don't get that sort of variation without some sort of variation in the frame, or external disturbance at the wrong time.
The only thing I can suggest trying is increasing your filter frequencies to 40 and see if your results are more consistent. (INS_GYRO_FILTER, RATE_PIT_FILT_HZ, RATE_RLL_FILT_HZ)
For future reference the parameters set by or interesting for a tune are:
ATC_ACCEL_P_MAX,
ATC_ACCEL_R_MAX,
ATC_ACCEL_Y_MAX,
INS_GYRO_FILTER,
RATE_PIT_D,
RATE_PIT_FILT_HZ,
RATE_PIT_I,
RATE_PIT_IMAX,
RATE_PIT_P,
RATE_RLL_D,
RATE_RLL_FILT_HZ,
RATE_RLL_I,
RATE_RLL_IMAX,
RATE_RLL_P,
RATE_YAW_D,
RATE_YAW_FILT_HZ,
RATE_YAW_I,
RATE_YAW_IMAX,
RATE_YAW_P,
RC_FEEL_RP,
STB_PIT_P,
STB_RLL_P,
STB_YAW_P.
Leonard,
I did switch to 40Hz filter and I got to say difference in numbers post-autotune is quite dramatic.
What is noticeable good is a realistic accel_y_max that is set now to a value that does not make vehicle jump like crazy in stabilize, and I see STB_ numbers all jumped up considerably. I will try to fly more later on new settings to confirm, only had 20min before first work meeting of the day today. .
Comparing files after-tune4.param and AFTER-TUNE3.PARAM
***** after-tune4.param
#NOTE: 9/10/2015 8:44:07 AM Frame :
ACCEL_Z_D,0
***** AFTER-TUNE3.PARAM
#NOTE: 9/8/2015 8:56:26 AM Frame :
ACCEL_Z_D,0
ARMING_CHECK,127
ATC_ACCEL_P_MAX,77163.51
ATC_ACCEL_R_MAX,137382.1
ATC_ACCEL_Y_MAX,17564.14
ATC_RATE_FF_ENAB,1
ARMING_CHECK,127
ATC_RATE_FF_ENAB,1
INS_GYR3OFFS_Z,0
INS_GYRO_FILTER,40
INS_GYROFFS_X,0.005611462
INS_GYROFFS_Y,0.01585633
INS_GYROFFS_Z,0.005035242
INS_PRODUCT_ID,5
INS_GYR3OFFS_Z,0
INS_GYRO_FILTER,20
INS_PRODUCT_ID,5
RALLY_TOTAL,0
RATE_PIT_D,0.02312991
RATE_PIT_FILT_HZ,40
RATE_PIT_I,0.3502205
RATE_PIT_IMAX,2000
RATE_PIT_P,0.3502205
RATE_RLL_D,0.007088783
RATE_RLL_FILT_HZ,40
RATE_RLL_I,0.2204735
RATE_RLL_IMAX,2000
RATE_RLL_P,0.2204735
RATE_YAW_D,0
RATE_YAW_FILT_HZ,1.347162
RATE_YAW_I,0.08630268
RATE_YAW_IMAX,1000
RATE_YAW_P,0.8630268
RC_FEEL_RP,50
RALLY_TOTAL,0
RATE_PIT_FILT_HZ,20
RATE_PIT_IMAX,2000
RATE_RLL_D,0.004
RATE_RLL_FILT_HZ,20
RATE_RLL_IMAX,2000
RATE_YAW_D,0
RATE_YAW_IMAX,1000
RC_FEEL_RP,50
SR3_RC_CHAN,2
STB_PIT_P,18
STB_RLL_P,14.56053
STB_YAW_P,4.746737
SUPER_SIMPLE,0
SR3_RC_CHAN,2
STB_PIT_P,4.837482
STB_RLL_P,9.45916
STB_YAW_P,4.601859
SUPER_SIMPLE,0
160
161
162
163
164
of 449 Next
