Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I saw something similar on the mission planner app with disarmed Copter:
The position was about 50 m away from the real position. With the M8N I had fast twitching number of satelites (12 - 18) with HDOP below 1. There was a good view to the sky (outdoor) I leave the copter disarmed for over 5 min but the position was at a more or less same position still wrong. Then I repowered the whole system the problem was instantly gone. I did not have any logs.
Hi. This is a question for the developers but I´m not sure it is a 3.3 only thing.
I have a big octa which has an extra battery for the gimbal and the pixhawk conected to an output so when I deplete the main one after flying, I can put a new one and I do not have to wait for everything to settle. The thing is that if the copter reaches failsafe voltage, it does everything that is supposed to (RTL) but once it lands, I can not fly again because the failsafe is not cleared even though the voltage is a 25.1
Is there anything I can do? Or is it a software bug?
It would be nice to have some way to warm up a multi with out having to have the main battery connected.
This feature would be valuable to any emergency services use where rapid deployment is needed.
Exactly. Another use is taking off from a boat. I need to start the apm on the shore to make the gyro cal and them move it.
With rc11 I am not getting Land and RTL reported by the GCS when I am still on the ground. This happens in both MP and APM Planner. The modes work and I believe they are being reported when flying, just not before arming.
I'm trying to autotune a QAV250 on rc11 and I physically can't do it even though I'm doing one axis at a time. I'm using a 1.8Ah lipo which gives about 6mins flight time and each axis takes longer than this. I just about managed yaw, but pitch was still going when I hit the battery failsafe. Any suggestions? I can't use a bigger battery - it's already pretty big for this size of craft. Surely there should be a way of limiting the autotune time? Anyone have some reasonable numbers for a QAV250 that I could use as a starting point?
Hi Andy,
If you do one axis and post it here I can tell you where it got to before you had to come down. That should make it faster for you.
The most important parameters to change for smaller quads is the filter frequencies:
RATE_RLL_FILT_HZ, RATE_PIT_FILT_HZ, INS_GYRO_FILTER
Set them all to 40.
I have done a write up on setting up smaller copters here:
http://diydrones.com/profiles/blogs/fpv-racing-using-arducopter
Thanks Leonard. I have now worked through your post in detail and will try again when the weather permits it.
Roll is:
P: 0.425
I: 0.425
D: 0.04
IMAX: 200
Stab RP: 3.469
Pitch didn't complete so I assume it didn't capture any values?
HI Leonard,
I tried again today with all the setup you mention and still cannot get pitch to complete. My flight time is about 7mins but that still isn't long enough. Part of the problem is that the vehicle is very light and agile so any wind will move it quite a lot (my bigger quad has a lot of inertia so does not move nearly so far or so fast). There's not much wind today but its still too much to simply leave it to get on with it and I keep having to bring the vehicle back. Hoping for zero wind at this time of year is unlikely.
Any suggestions? Is there any way to capture intermediate results on a single axis?
andy
Hi Andy,
I can look at your logs and give you a better starting point if you like.
146
147
148
149
150
of 449 Next
