Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • This is probably not the right place to post this, my apologies, but as there are a number of devs on this thread, perhaps I can get pointed in the right direction.
    My hexa is flying nicely with 3.3 and Lidar Lite, so I thought it would be a good time to try out my PX4Flow. Used QGC to update the firmware and set the focus, then plugged it in. First problem I have run into is that it has to be powered by USB before the main battery. Apparently, it is a known problem and it says on the wiki to notify the devs, but it doesn't say how/who/where. Is there any workaround for this? One thing I did notice, that may help to narrow down where the problem is, is that if I power it with the battery first, the altimeter on the MP GCS shows the altitude going up very rapidly (goes up to thousands of feet), but when I check the baro in the log, it shows the altitude correctly.
    Is the OF functionality going to be enhanced in 3.4 and is there a spec for it anywhere? Thanks!
    • I with you, lidar and PX4flow on the bench...
      Info is still sketchy.
      • Tested my height following with lidar today. Passing close over my car ( noooooooo ) and even over me and it works beautifully. My only comment is that we need some indication of what is in charge of height,  ( as opposed to altitude ). An indicator on the GCS that the vehicle is height controlled ( sonar/Lidar ) as opposed to altitude ( Baro/GPS )  would be nice. Perhaps even an added channel control to follow sonar/lidar - terrain following?
        copter 3.4 anyone?
  • The escs are 30A with blheli, batt cutoff disabled, flew them on a big apm hexa for 2 years with no issues, this build is a small quad 1000kv motors with 9x4.7 carbons, same escs Tgy AE30. I just finished the repairs, I have found no problems with any of the soldering/wiring.Uploaded 3.2.1 and will put it trough serious trials, although I've already done that for a few days prior to the crash with 3.3. Thank you all for inputs, I'll keep you updated.
    3702597234?profile=original
    Hi Trent,
    It is very clear from your log that you lost motor/esc 4. I can see from your log that this happened very quickly but it also didn't stop fully so you may have burnt out some windings on your motor. Based on the fact you didn't lose the thrust completely I suspect you don't have a problem with your wiring. You may have lost some of your fets in the esc. You may also have a prop loose or broken (but I suspect you would have seen that). Problem is you should have seen all this in your next flight.
    The only other thing that may have caused this is noise on your signal line connecting your pixhawk to the esc. I have had this problem on my high powered quad and had to make sure I didn't run the ESC servo wire next to the power wires.
    The only good news is this isn't the autopilot, it is something between the output of the pixhawk to the esc, the battery, to the prop.
    This one is a head scratcher. Sorry I can't help more!!
    I also tried to download the log and could not becomes of a permission problem.
    Hi Trent,
    Sorry about your crash. I can't download you log. Can you give me permission?
  • This is my first post on diydrones, so hello everybody! Unfortunately I have to start with a crash. To cut the story short because I think I may have encounter a serious issue with AC3.3. Uploaded the firmware about a week ago, mainly because of the LG an Storm32 support. Flew without any issue, only once I think when I RTL in the descending phase over home is started wobbling kind of serious, I had to put it in stab and descend manually and it settled. All other autolandings were fine. Now the main issue, took off yesterday for the second time (on the side note, I was conducting a search over the sugar cane filed in search for a lost arduplane, flew LOS at low alt over the field and got caught in a downdraft, plus it was getting pretty dark) after a steady 6-7s climb (see log) the copter destabilized and crashed pretty badly right on the schnoz, (good thing it was wearing the newly handcrafted, perfectly balanced ST32 gimbal as a helmet). Looking at the logs I was puzzled to see that ch3 out went completely idle right before the crash for no apparent reason, the mag acc an gyro were stable, and the time frame tells me that the ch3 went dead prior to any change in the imu.I hope you guys can clarify this, maybe I am missing something. Just to add, my builds are very sane and thoroughly checked to the last detail, I'm a bit of a freak in this field so a mechanical problem is most likely out of question. I'll upload the video shortly, my internet conn is knd of sluggish.
    33.BIN
    Ed AC3.3.param
      It looks like a mechanical failure of the back right motor or ESC (#4) because the actual lean angle suddenly diverges from the desired and it rolls back and right.  The motor output backs this up because motor #4 suddenly goes to full while it's opposite (#3) goes to it's minimum.
      3702597212?profile=original3702597377?profile=original
      Just for reference, the motor numbers can be seen on the wiki here.
      • I hope you're right, but I'm still not convinced what's the cause and the effect, from what I see the commanded motor reaction caused the roll, not the other way around. Some random acceleration/deceleration of the the motors is unlikely (checked all the motors/escs afterwards and they seem fine and within parameters), all my wiring is soldered, the single connector being FC-ESC and the pins are soldered also, not just crimped. And besides there's an inconsistency in ch4 out trying to stabilize while the ch3 stays low to the end with just couple of spikes. Obviously I know the motor numbers, the copter flew fine a dozen times with 3.3 and I am AC user since versions 2.xx and believed or not never had a crash, of course there's a beginning for everything, I am not frustrated about the crash though, I'm just trying to understand the cause. I'm also aware that I'm only human and did, can and will fail at some point with whatever I do, just want to find out if I just did or it was a divine firmware/hardware intervention.
        And the video is ready (edit) at the end you can hear the lipo burst into flames. https://youtu.be/eAAU4joQtRg
