Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Nice!! Thanks for the report. It does seem better in the wind than 3.2 doesn't it?
      • I'm not a reference to ensure that because this copter is the first time that fly well with so strong wind; it wasn't so quiet for a nice video, It's need a fine tunning yet but Isn't a day to take nice quiet videos (and no my interested too, I like photos), but the copter looks strong flying against the wind. I'm very happy :D
    • that's very nice to hear!!
  • I tested 3.3.1RC1 now, and works well.  I tried all flight modes.
  • I'm going to give a try today too if weather permits and report results.
    Randy, I share the log of my failed take off here, http://diydrones.com/forum/topics/copter-3-3-beta-testing?commentId... , we wrote a lot of pages them and I affraid you can't notice or you can't open; if you don't have enougth time to see, or a human err only, no problem, isn't so important, I know that I have to pay more attention when I take off.
  • Randy, I'll test today.  I 'll write the result at 2 PM ( UTC ).
    Has anyone given Copter-3.3.1-rc1 a flight test?  I'm thinking of releasing it soon but I just want to be sure some other people besides me have tried it.  The bug fix is incredibly minor, it's more the compiler upgrade that I'd like to have a bit more confidence in.
    • 6 flights today with my rebuilt copter.
      Everything is fine.
      Good to go!
    • I have been running for a few days with no issues.
      Have about 8 flights and about 2 hours flight time with no issues.
    • I've done a half dozen flights with my quad and hex with no problems. Very stable and prdictable. Auto missions are solid however I did not try to replicate the bug.
