Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I think this was just a rationalization of what the value needs to be.  I've been pushing for it to be 4500 for a long time, which is what I typically run.
  • test flight a while ago, hovered it  3 meters away from me. My quad went to failsafe due to low battery. but instead of landing, it performed RTL instead of LAND. I thought it should choose whether to LAND or RTL based on hardcoded 5m rule? is this normal? Luckily i was able to switch flight modes to cancel RTL else it should have hit the wall.
  • Hello!
    I used version 3.3.1 with coaxial octorotor. I try take off in Stabilize mode. Compass and GPS disable, because next step I want use PX4FLOW. But when I move throttle stick only on one step coaxial octorotor take off very fast and I cann't control it, when I move stick back on one step throttle too small for take off.
    When I use 3.3.1 with quadrortor everything all right with take off.
    Can somebody analyze my log? I will attach the file coaxial octorotor. thanks!
    2015-11-06 09-26-13 95.bin
    2015-11-06 09-26-13 95.bin.log
      I don't see anything in particular wrong.  I'd recommend trying a few things:
      • re-calibrate the ESCs
      • do the motors test to ensure the motor order and direction is correct (check the props too!)
      • if the above doesn't help, try going back to Copter-3.2.1 (it's still available through the MP's previous firmware link) so that we can be sure it's a firmware issue.  If Copter-3.2.1 works but Copter-3.3.1 doesn't then it's likely a firmware issue and we can look into it further.
    • I had a quick look.  Has this vehicle flown before?
      I don't see anything wrong though I'm not the expert in multirotors.  I see your motor outputs are about 1250uS PWM on the first test.  Then the second test they don't go above 1500, I think it flipped over?
      I suspect it might just be that your multirotor is overpowered, or the ESC's aren't calibrated properly?
      • Thanks for looking into Rob! But when I use prevuious version 3.2 with this coaxial octorotor everything all right (I didn't change battery and didn't calibrate ESC's). I change only version APM. With 3.2 I can control multirotor. With 3.3.1 it flipped over.
  • I have two Pixhawk running arducopter with version 3.3.1 and one with
    3.4-dev. The two have a message via NSH Overtime task 19. Is there a problem in flying that way.
  • Wil there be ever oneshot support with pixhawk in the future?
