Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • See this is the thing about "faults" is the never really go "hey, I'm about to break" Just because they worked "yesterday" doesn't mean they will work today :( And the thing about these darn desync issues is that they don't always pop up and rarely when you expect them. Intermittent problems are the hardest to diagnose. The logs "should" give you an idea where to look but I am so out of touch with all the new logging info that I would not have the 1st clue where to look. You might not even have the needed logging enabled. There are quite a few videos on desync issues and how to reproduce them so you might want to take a search on youtube.
        Are you sure all of your props were tight? The only time I have seen that kind of spin on one of my hexes was when it spun a prop lose and down it came spinning like a top. The only time I have had a desync issue was on my 250 quads and they tend to just flip and crash.
        But I would definitely look at your vib levels even so as they are not good and are bound to cause you issues in the future. The video showed some pretty heavy oscillations [vibes] and whilst I do not think they are what brought down your bird "this time" I would fix them before flying again.
    • The jello in the video confirms that is is pretty much either a vib issue or a desync issue or possibly both. Normally a spin like that means one or more of the motors went wonky. This could be an intermittent ESC issue, cold solder issue, a wiring issue, or a motor issue.
      • In a desync / esc issue shouldn't the rcout channels log the failure by its attempt to raise the throttle in order to try to maintain the attitude?
    • Hello Dave, Have you checked your motors
      • Hello Dave,
        I thought it could be a motor sync issue, but after taking a look at your logfile it seems that they are fine.
        There is something going on with ekf. Don't know what is it. Someone more experienced with ekf would probably figure it out. I see that the ekf mag innovations are high and your vibe(x,y,z ) are very high despite the IMU vibration levels are fine.
  • Still unable to find the THR_MAX setting in 3.3.1 with Hexacopter in X. Does anyone else see it? Is it a missing setting in this version? My copter won't take off.
      Brad,
      Sorry for the slow response.  I may have answered your question on the APM:Forum but in case that wasn't you, you can use MOT_THST_MAX to reduce the maximum possible output to the motors.
    • This reply was deleted.
      • pretty sure he said he is running DJI opto and DJI motors which means he can't run the endpoint calibrations as the DJI stock firmware doesn't support it.
  • I'm having lots of problems with mavlink telemetry both through bluetooth and minim OSD. minim OSD now almost never works. Resetting the board doesn't help. Repowering very ocasionally works. I think its more likely that these devices simply aren't receiving mav data. Is there anyway to make this more reliable? I'm also going to try going back a couple of revs because it wasn't this bad before. Could still be my hardware, but just seems odd.
    • Its as simple as setting correct SR settings for the correct SR port# and choosing the correct serial port. P.s. also, if you are using a **hawk its a god idea to reflash bootloader.
      p.p.s. Do not forget to disable flow control for the minimosd serial port.
