Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Artem,
The compass variance should only happen when the compass doesn't agree with the other movement of the copter. So if it was oriented incorrectly that would certainly appear. It can also happen if there's interference from the motors or if there's metal on the frame that warps the magnetic field.
By the way, the "compass variance" is not actually triggered by having internal and external compasses that disagree. That situation produces the very similar "inconsistent compass" pre-arm message.
O, ok, thank you Randy for responce. So if compass movement doesn't agree with lets say acc data this message will be triggered as well, correct?
What transmitter is that? Are the voice/speakers stock?
Thanks for the clarification. Wasn't sure if George-Kelley was advertising a different radio, my apologies.
It's surprising that it isn't that expensive?
My radio of choice previous was an Aurora 9 which was expensive and limited in functionality as well.
Thanks for the information.
16 channels haha wow
Yeah I get that. Hitec is a really good company and I hope they match the competition.
HobbyKing's 'Taranis-killer' (ok, exaggerated, but it's HK) is on sale for 50% off right now - the Turnigy 9xr Pro.
$50 instead of $100, for Black Friday.
Includes speaker and voice alerts. Some people are hacking the speaker for more volume, and substituting their own audio files (see dedicated thread on RCGroups.com).
I've ordered one. It's HobbyKing, so wish me luck.
(hope I'm not violating TOS by mentioning this)
George
Haha that's a joke right?, that radio in the video looks like a Spectrum DX something or Airtronics not a cheap Hobby King transmitter.
Did a quick test flight today with my Hexa Copter version 3.3.1. Rebuild to reduce vibrations. Did all calibrations, but now i get compass variations during flight.
Can someone please advice ?
Thanks...
2015-11-26 10-55-23.bin
Hi Randy,
Probably busy after holidays and upcoming release.
Can you please take a look at my issue.
Thanks..
Randy
Is this the file I need to direct APM P2 to install in my quad frame / pixhawk to test boat mode? ArduCopter-v2-2.px4
64
65
66
67
68
of 449 Next
