Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Artem,
            I started a discussion on RCG about coaxial efficiency per eCalc authors. I tried various prop combinations and found the most stable to date was using Xoar 15x5 top and Xoar 14x7 bottom, tried different timings as well which did make a difference.
          As you can see, I had the same problem as you:
          Below is with Xoar 15x5 top and Xoar 14x7 bottom. I bought some 14x8 but broke one of the blades and never reordered. I now have genuine T-Motor 15x5.5 top/bottom and it is not as stable; haven't flown it for quite some time but want to put the Xoar 14x7/14x8 on the bottom. One thing I'll say is the cheap props flex way too much and cause oscillations.
          I also believe the axial distance between the props changes things as well, and with much confidence conclude no two Y6's are the same (had three of them), nor does one size fit all. I'd like to try BLHeli firmware on the HW Xrotor ESC's on this copter.
          Xoar 15x5 top Xoar 14x7 bottom. Very stable and reduced VRS substantially.
          Link to RCG discussion:
          http://www.rcgroups.com/forums/showthread.php?t=2365475
          Link to eCalc essay:
          http://ecalc.ch/calcinclude/help/xcoptercalchelp.htm#hints
          Hi Artem,
          Sorry, Typo. KV
        • Hi Artem,
          I use 13x5 upper and 14x7 lower. Rcout is almost equal for upper and lower motors.
          3702802841?profile=original
          • 3702854085?profile=originalThx,  what is your AUW and motor  KV? Thank you!
            • AUW 2650g
              Pixhawk AC 3.3.2
              Neo M8N
              EMAX MT3506 650KV
              Kiss ESC 18/30 A
              Multistar 10Ah 4s 10C.
              Aeronaut Cam Carbon light 13x5 upper / 14x6 lower.
              ->26 min hover.
              I also tried APC Electric 13x4,5 / 14 x 7.
              Both Setups work fine. I think for an efficient coax setup you need more pitch and larger diameter for the lower prop.
              • Yep,  AUW is about what I thought. Thank you!
            • Everything I've seen tested so far is either from a test stand of hovering.  Like helicopters, once you start to move and enter ETL (effective transitional lift), a lot of the vortex interference will dissipate.  given the vortices travel downward, I wonder if mounting the rear arms higher than the front arms would help?   Sounds like a job for Simscale : )
              • Its a Y6, coaxial.
                • Then you'd just raise the single back arm.  Funny you'd mention a Y6, I was thinking of a Gryphon 1400 Y6 with a bent arm on the rear and 6 of the new KDE 8218's.
  • Any suggestions on improving noisy IPD EKF values? It appears that it is mostly related to a Noisy Barometer. I've got vibrations well below acceptable levels.
    The Pixhawk is housed in an rctimer dome.
    I loose about 5-10 feet of altitude transitioning from hover to directional flight. I've increased EKF ALT Noise to 3.7 and its subdued the rather aggressive drop to a sustained slow drop over about 10 seconds vs 1-2 seconds.
    Still would like to improve on this.
    2015-12-02 17-35-49.tlog.zip
Aug 25
