Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
AutoTune can be setup as a flight-mode....can i use 3 position switch where is;
1st STABILIZE 2nd ALT HOLD 3rd AUTOTUNE
Do i exit autotune by switching to alt hold or stabilize?
For some reason as I recall I couldn't do auto tune on a 3 position switch but I forget why. I think because you can only find auto tune on the ch 7-8 options and on my radio those are a two position switch. I don't like that. I wish every channel had every option. Maybe there's a reason but I don't know what it is. Here's a better explanation of how to exit / use and or save the auto tune PIDs than I could explain http://copter.ardupilot.com/wiki/autotune/
From 3.3 you can make Auto tune as one of the flights mode,not only on ch7/8..thank you,i did many autotune but never this way,read your link
It's funny after reading the wiki again I might have been doing it wrong myself. I thought once it was done doing the auto tune you leave the toggle switch in auto tune and land and disarm to save the new pids. However... after reading it again it says after it is finished it goes back to the original pids.. you need to manually flip back to alt hold [ or whatever ] and then back to auto tune again THEN land and disarm to save the new pids At least that's what it sounds like in the wiki.
I understand that before AT process you can compare old and new pids turning on/off ch7/8 during the fligth and how pids are when you disarm are the saved pids (new with switch on or old with switch off) ; but before autotune I don't have enougth batt to many test so what I do is: first to save the old pids-autotune-change batt-test if I like it or reload the old ones (.....But my english is not warrantee so correct me if I'm in a mistake)
What I did the last time was use a dial on my TX for ch 7 then set the P the I and the D one by one by dialing in each one up until it's was too twitchy then just back it off a bit. Very cool.
I've never done it that way After AT finishes I switch to stab then land and then disarm. Pids are always saved for me. Though I still prefer to use Sw7 to turn on/off AT and whether or not I actually use the PIDS set by AT is a different discussion all together :)
Okay got it now.. thanks!
it sounds wrong,you just land and disarm ,and pids are saved..
