Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Try to reduce "Stab and Rate" YAW P about 1/3.
      I use this trick also for Roll and Pitch, a little overtuned on my big birds, like in my video on this thread.
      • HI!. Thanks for the information always so I do from AC 3.1.5 and it works quite well. But now, Pitch and Roll has a very low P rate and very high I, while Yaw too high P and I corrected what I can in this way
  • Hi! How many minutes does autotune require to complete the entire cycle? I am having a hard time doing so since my flight time is just 7-8 minutes with my current setup.. I always end up landing the quad due to low voltage...
    • Wow! That's new for me! :) I did not know that I can select which axis to perform auto tune on :) thanks again. I will try tuning tomorrow and see how it goes.
    • If all is going well you may have a minute or so to spare Autotuning
      Hi Erwin,
      I am glad you asked :)
      AUTOTUNE_AXES controls which axis is tuned.
      1 is roll
      2 is pitch
      4 is yaw
      So then you add them if you want to do multiple axis so
      3 is roll and pitch
      7 is roll, pitch and yaw.
      So do one axis then put a new battery in and do the next axis.
      Let us know how you go.
      Leonard
      • Hi Leonard,
        So I attempted to tune today my Y6B and ran out of battery as well.  So back to re-reading this post.  So if I understand you right, multiple axis tune is adding any sequence of 1, 2, or 4 to get a total for what you want the copter to tune to.
        Example:
        1 + 2 = 3           So 3 is what I put into AUTOTUNE_AXES to get it to tune just Roll and Pitch
        2 + 4 = 6           Would be to tune Pitch and Yaw only
        So I tried to enter in a single axis tune such as Roll (1) but the mission planner stated not a valid number. However after entering 2 and 4 and then back to 1, the mission planner didn't balk at me for enter 1 into it.
        At this point I disconnected power to Y6B and re-powered and connected to find I could not repeat the error message.  Hmmmm.  Gremlins.
        Thanks for explaining the Autotune configuration settings.  This will help me tremendously to tune my Y6B using the 6000 mah batteries I have.
        • So cool!
          I set my Autotune_Axes to 1 and Roll was successful. Tomorrow (weather permitting) I will plan to perform Pitch test only.  Attached is my logged flight for anyone to review.
          3702782747?profile=originalOutside temp = 61F
          Humidity = 55%
          Winds = Calm
          On a separate note. I noticed on all my test flights that the GPS status indicated in the AutoAnalysis stated FAILED Satellite min 0.
          However, when I reviewed my logs, they showed both GPS units (NEO-M8N (P) and LEA-6H (S) held satisfactory number of satellites and both had low HDOPS (below 2.0) for majority of flight.  However it FAIL due to HDOP hitting above 2.0.
          So the question is, is it truly a FAIL as most of the flight it stayed low?  I suppose if it goes up at anytime during the flight it's considered a FAIL for GPS status.  Guess I'm glad I wasn't in Auto.
          Log File C:/Users/Doug/Documents/ArduCopter/UAV Logs/HEXAROTOR/1/2015-04-15 19-31-14.log
          Size (kb) 20005.1103515625
          No of lines 269057
          Duration 3 days, 23:45:27
          Vehicletype APM:Copter
          Firmware Version V3.3-rc1
          Firmware Hash 5a4039d9
          Hardware Type
          Free Mem 0
          Skipped Lines 1
          Test: Autotune = NA -
          Test: Balance/Twist = NA -
          Test: Brownout = GOOD -
          Test: Compass = GOOD - mag_field interference within limits (16.48%)
          Max mag field length (564.60) > recommended (550.00)
          Test: Dupe Log Data = GOOD -
          Test: Empty = GOOD -
          Test: Event/Failsafe = FAIL - ERR found: FS_BATT
          Test: GPS = FAIL - Min satellites: 0, Max HDop: 2.5
          Test: IMU Mismatch = GOOD - (Mismatch: 0.36, WARN: 0.75, FAIL: 1.50)
          Test: Parameters = GOOD -
          Test: PM = NA -
          Test: Pitch/Roll = NA -
          Test: Thrust = NA -
          Test: VCC = GOOD -
          2015-04-15 19-31-14.zip
  • "support do-set-home command (allows return-to-me and locked home position once GCS enhancements are completed)"
    Can somebody provide some information on this specific feature above (10.a)? Is this implemented and its currently usable? If not, then when will it be available?
    Evan
