Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Have you tried to change it via the full parameters list? It should let you set any value i think and keep it.
Is pixhawk with 3.3.x always using EKF or still as a option controlled with AHRS_EKF_USE ???
Ok found it "In Copter-3.3, this feature is forced to “1” and cannot be changed"
What the link to Copter-3.3? Thanks in advance.
http://firmware.diydrones.com/Copter/
Thank you, This is the link to firmware. But where can I read about all new (and old parameters)?
I read a post by Randy saying the PPM Channel Mapping issue would be resolved before 3.3 went final. Does anyone know if that is done?
It's done. I am flying with it - it works well.
Hi Andy,
I am still having issues with RCMAP in rc5 with my Pixhawk, using cppm via a Frsky DR 4 II and a JR PCM 9x with Frsky tx module.
In the full parameter tree (Mission Planner) I change the channel assignments to match the JR (TAER from AETR).
Perform a Radio calibration which all works fine then go flying. Trouble is the craft always rolls to the left.
This has been the case for me since I switched to 3.3, worked great in 3.2.
If I use a FrSky 8 channel RX via the PPM converter, plugging the channels in appropriately, and not using RCMAP all is OK.
Is there something I am missing?
It's not in rc5 - you need to build from source right now if you want to use it.
HI Dev's, are we close to RC6 (or a release). RC5 is working great on my hex, Cheers and thanks! MIke
